Poll: Can you fit a finger between the earth and the wire?
Poll Options
jyl jyl is online now
jyl's Avatar
How Good Is Your Intuition? (Mind-Teaser)
There is a wire, whose length is 10 feet longer than the circumference of the earth at the equator. The wire is formed into a circle, slipped over the earth, and placed at the equator. Assume the equator is also circular and smooth (no mountains or oceans). Can you fit your finger between the wire and the earth?
Old 01-17-2011, 07:44 PM
AutoBahned
RWebb's Avatar
ok, what's the trick?
how cold is it?
what kinda "circle" - the kind with left over wire?
what kinda "Earth" - the kind with flat poles? slightly pear shaped? wire orientation re part 1?
Old 01-17-2011, 08:00 PM
jyl's Avatar
Don't be a woolly-minded liberal.
There is no thermal expansion or contraction.
The wire is joined end to end. If I meant a circlip or a split ring, I would have said so.
The equator is circular and the wire is placed over the equator.
Old 01-17-2011, 08:08 PM
AutoBahned
RWebb's Avatar
ok, then "No" - because I am too far away from it to reach mah fanger ovah theah
Old 01-17-2011, 08:18 PM
Almost Banned Once
sc_rufctr's Avatar
NO... Even though the wire is 10 feet longer than it has to be the thickness of the wire would mean it would be very tight against the Earth.
(Standing proud of the Earth by half it's thickness)
- Peter
Old 01-17-2011, 08:21 PM
winter-hater club member
nynor's Avatar
yes. if there is ten feet of slack you should be able to pull it up nearly 5 feet at a single point. giving you more than enough space to stick your finger under it.
"COOL PRIUS!" - Nobody Ever
Old 01-17-2011, 09:38 PM
jyl's Avatar
Ok guys, play it straight. As stated, the wire is a circle, the earth's equator is a circle. No stretching, deforming, digging a hole in the earth, etc. This is a test of your sense of geometry and scale, not your ability to invent loopholes :-)
Old 01-17-2011, 09:50 PM
nynor's Avatar
then, there is no way.
Old 01-17-2011, 09:56 PM
AutoBahned
RWebb's Avatar
depends on the thickness of the wire
but then.. if it is too thin, it'd just cut right thru your finger...
Old 01-17-2011, 10:02 PM
This is a bunch of BS.....
Old 01-17-2011, 10:09 PM
cantdrv55's Avatar
No because of pi?
Old 01-17-2011, 10:49 PM
durn for'ner
livi's Avatar
Easily. There will be approximately a 3 feet gap.
Markus
Resident Fluffer
Carrera '85
Old 01-17-2011, 11:11 PM
Won Won is offline
Won's Avatar
10/(2*pi) ft of gap?
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 01-17-2011, 11:19 PM
Now in 993 land ...
aigel's Avatar
What he is saying is that there is a circle with the circumference of the earth and then there is another circle with the circumference of the earth +10 feet. If you put them concentric to one another, will you be able to fit your finger between the two circles ..
I just did the math - no intuition here. Let's see what you think ...
G
81 SC (sold)
Schumi's Avatar
Yes, you could.
This could be easily proven algebraically, but I'm too tipsy.
The problem does not state that the wire has the be evenly gapped around the earth (which is assumed)- if this were the case, no way. But if the wire was zero mass and zero thickness, it could easily be pulled taught until all the slack was in once place, and the wire met, with 5 feet of slack overlapping for a total of 10 feet of slack. Plenty of room for a finger.
M
Old 01-17-2011, 11:30 PM
Schumi's Avatar
G
He doesn't say they have to stay concentric to each other.
M
Old 01-17-2011, 11:31 PM
Now in 993 land ...
aigel's Avatar
Maybe not concentric but the new circle has to include the old. But they have to be circles, not a circle and a 10 foot loop.
G
81 SC (sold)
Old 01-17-2011, 11:34 PM
Schumi's Avatar
eeh, When I think of 'wire' I think something that can be bent around. If it has to stay a circle, why not just call it a circle? Oh, I see, it's part of the sensory intuition of the problem...
M
Old 01-17-2011, 11:38 PM
there's lots of slack on a ski lift cable. But you won't catch me putting my finger under it.
Old 01-17-2011, 11:44 PM
Information Junky
island911's Avatar
with no intuition and no exact math (just reason)... if you split the wire (wrapped tightly around) in two halves (180° apart) then splice in a couple five foot Sections, much of the wire would be a couple feet off the surface. ...Now imagine splicing in that 10' section in quarters,... spliced in at 90° apart. . those original arcs are pushed off more than a finger.
Old 01-18-2011, 12:13 AM
