Almost Banned Once
sc_rufctr's Avatar
How do I fix this?
PLASTIC Headlights on a Merc!
Is it possible to buff these back to clear or do I need to buy new ones?
I know I can get a kit with the polish and stuff to fix plastic headlights...
But has anybody done this to Merc Headlights?
- Peter
Old 01-24-2011, 09:51 PM
crustychief's Avatar
I used the kit on my Land Rover. I was pretty satisfied with the results considering replacement costs.
Or you could just get some 2000 grit wet or dry sandpaper and work your way up to a fine cutting compound followed by some plastic polish.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 01-24-2011, 10:04 PM
Embraer's Avatar
unless you pull the headlights to do it, be sure to tape the edges. if you're buffing them, you will burn through clearcoat in about .2 seconds
edit: i would do it by hand. forget the makita
-mike
Old 01-24-2011, 10:09 PM
a.k.a. G-man
Geronimo '74's Avatar
I have the same problem with my VW, though not this bad.
Is there any way to prevent it from dulling again or protect the lenses afterwards too?
(sorry, not meaning to hijack)
Old 01-24-2011, 10:27 PM
Run smooth, run fast
Heel n Toe's Avatar
Peter, what you have is a Benz, not a Merc.
If you had one of these, you'd have a Merc:
- John
Old 01-24-2011, 10:29 PM
Almost Banned Once
sc_rufctr's Avatar
You'd need something to protect the plastic from the suns UV light.
Maybe a standard two pack clear coat would work...
- Peter
Old 01-24-2011, 10:47 PM
Almost Banned Once
sc_rufctr's Avatar
I like this one
- Peter
Old 01-24-2011, 10:48 PM
Won Won is offline
Won's Avatar
3M Headlight Restoration kit gets good reviews. I need to do the job on the bimmer soon. Some people paint the headlights with clear right after it's been restored with good results, I think I'll just leave mine and repolish in a few years if the need be. Or you can keep it shiny with the Maguires Plast-X.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 01-24-2011, 11:22 PM
repp's Avatar
the headlight restoration kits work just fine in most cases.
iv run across a few that had to be sanded iv done around 15 pairs and only one was beyond repair
86 carrera coupe, track & daily driver.
7 other unimportant cars (mostly VW's)
1 very cool dog. RIP my friend
no kids, no wife, HELL YEAH.
Old 01-25-2011, 12:14 AM
repp's Avatar
I have used plastic buffing compound on a stand up buffer and its the best
Old 01-25-2011, 12:16 AM
Almost Banned Once
sc_rufctr's Avatar
Thanks... That's a good suggestion. I've got a bench grinder mounted on a pedestal in my garage. (I've got buffing mops for it)
The car belongs to a girl I've been dating for about 6 months so I want it to look perfect when I'm done.
- Peter
Old 01-25-2011, 12:19 AM
repp's Avatar
be very gentle as the buffing wheels like to burn plastic.
very light pressure if any at all and it should be fine
Old 01-25-2011, 12:22 AM
fastfredracing's Avatar
I have used the kit with the sandpaper, and 3 different grade polish with good results, however, I recently ran out, and used a generic product that I got from the local Advance auto parts. It is a one part product, and does not require any buffing or sandpaper. Use it like wax/polish. Easy on, easy off. It works excellent, and is super easy. I cannot remember the name right now, I will look at it when I get to the shop this am , and post it up later.
No left turn un stoned
Old 01-25-2011, 04:16 AM
MAGA
Tim Hancock's Avatar
I have always just used a 3M buffing compound (which pretty much works for anything from plastic to paint to aluminum) both by hand and by machine.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 01-25-2011, 04:24 AM
New kid in town
71T Targa's Avatar
I did our Toyota's headlights with the 3M kit and they came out great!
How to polish plastic headlights?
I wish I still had 9111113443...
Old 01-25-2011, 07:02 AM
Pre Registered
tchanson's Avatar
Originally Posted by 71T Targa View Post
I did your Toyota's headlights with the 3M kit and they came out great!
Another vote for the 3M Headlight Lens Restoration Kit
You need a proper speed drill, and its a little disconcerting when you first grind down the lenses to a completely opaque white, but the end results are pretty good.
30 minutes and about $15US, as I recall.
Tim
Old 01-25-2011, 07:14 AM
I just used the Maguires kit and it worked awsome. $24.99 at your local auto parts store. It comes with the sanding stuff, a buffer, and the polish.
1976 911/S/SC/BASTARD
Mid9 Member #12
Old 01-25-2011, 08:16 AM
Seldom Seen Member
Burnin' oil's Avatar
I wet sand with 800, 1200 and 2000 grit. Couple bucks and like new.
Why do things that happen to white trash always happen to me?
Got nachos?
Old 01-25-2011, 08:18 AM
Senior Member
I like this one
I grew up in a 1950 Merc two door coupe. Three on the tree with a flathead V-8, never should have sold that car!
Old 01-25-2011, 08:19 AM
A930Rocket's Avatar
I used the 3M kit and it worked good but I'll be darned if the foam pad was wrecked when it got caught in one if those headlight nubs. It was worthless after that. Either cut them down smooth or be very careful around them.
Old 01-25-2011, 08:53 AM
