Registered Abuser
MT930's Avatar
Originally Posted by Tim Hancock View Post
If you need to weld the flap to the shaft, I would simply drill a couple small holes in the flap where the original crimp indentations are and then I would simply rosette weld them with the tig welder..... Very simple IMO...
Yep or a timed spot blast with the TIG torch. I weld Nickels together with out filler rod.
With Epoxy your always going to be thinking of it.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 02-11-2011, 12:33 PM
pete3799's Avatar
Originally Posted by Seahawk View Post
Honestly, Tim, WTF do you know...I mean, really
Yeah.....like he's ever welded anything
Pete
79 911SC RoW
If welding isn't an option, how about drilling a small hole & driving in a split, tapered pin?
Marv Evans
'69 911E
Old 02-11-2011, 12:45 PM
Schumi's Avatar
As explained above, two small holes with some rosette welds won't get it very hot and will hold just fine.
If I had my TIG here Denis I could do it easily for you.
I'm thinking about purchasing one again soon.
M
Old 02-11-2011, 12:46 PM
Team California
speeder's Avatar
Thanks for all the replies. Tim's solution is the winner, I just need to go to the welding shop and have them TIG weld it. I already drilled the holes. I'll post some pics later. Thanks again!
Denis
Team California
speeder's Avatar
Done deal!
As usual, this board rocks. Tim's solution was the best because what I did not show previously is that the flap has a small bracket on the back that attaches linkage to the other flaps and is under minor stress. Minor but enough to make the "smush it together" or epoxy fix a probable (quick) failure. I knew that it needed to be welded, just wasn't sure the smartest way. It also needed to be repaired with the whole thing assembled.
Here are the holes:
Here are the linkage rods:
Took it to my guys @ Hollywood Welding. This is where James Dean would have taken any welding work on his bikes or cars, not to mention McQueen, hell, Errol Flynn for that matter. Look at the year on sign:
And done! A good day so far. I managed to also fix the other one which was really mangled. Pretty sure that they will both work. New repros are available but pricy, ~$600 for a set.
Denis
Old 02-11-2011, 02:19 PM
Senior Member
Believe that this might have to be nominated for "post of the month" if not year...
Old 02-11-2011, 03:29 PM
MAGA
Tim Hancock's Avatar
Good to hear you got it fixed..... I hope they did not charge you much as that is a piece of cake with a tig welder. A wire welder could have worked also, but when tig welding through a rosette hole one can be 100% sure that the shaft gets melted/penetrated prior to dipping in the filler rod thus melting/mixing it together with the outer sleeve. I use rosette welds all the time when internally splicing chrome moly aircraft tubing.
While some of the other ideas would have worked, five years from now Seahawk won't have to explain to his wife why his heat system just started acting up in his silly old German toy car as they are on a fall color tour two hours from home.
Keep up the good work Denis... don't let Seahawk rush you... quality resto work like you are doing takes time.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 02-11-2011, 03:34 PM
Senior Member
Superman's Avatar
Seriously. Shakespearean.
Mocha 1978 911SC. "Coco"
Old 02-11-2011, 03:58 PM
Senior Member
Superman's Avatar
Yeah, me too.
While some of the other ideas would have worked, twenty-five years from now Seahawk won't have to explain.......
Fixed it for you.
Old 02-11-2011, 04:00 PM
MAGA
You guys should have seen the crap I cobbed when I was a broke high school and college student.... I had zero patience, knew just enough to get in trouble mechanically and I was satisfied with a repair that lasted a week.
Competitive MX motorcycle racing, building model then real airplanes, a mechanical engineering degree, buying old beat up Porsches and acquiring a few gray hairs somehow changed my attitude over the years..... I pretty much am to the point that when it comes to mancave projects I live by the old saying: If it "ain't" right it's wrong..... (Of course this is just my opinion... my wife would disagree when it comes to me working on/improving "her" house )
I have no idea how much past experience Denis has on projects like this, but he appears to be detail oriented and seems like he has a similar mindset on approaching this type of preservation/resto work. I especially liked how he figured out a clever way to wire brush the torque tube interior prior to painting them. It probably did not "need" to be done, but damnit... it just would not be "right" to pimp slap the clean shiny parts back in there with that tube looking like hell inside.
Keep up the good work Denis! I know all too well how tempting it is to rush the last few tasks when nearing completion of a long term project.
0% Liberal
Old 02-11-2011, 05:18 PM
Team California
speeder's Avatar
Thanks, Tim. For the encouragement as well as the solution to the flap issue. I have zero experience with 356s before this but a bit of 911 DIY time including rebuilding the engine of my SC back in '02(?)
I'm not capable of rushing on something like this, just too OCD or something. I'm putting on the engine sheet metal right now and it's going slower than I anticipated because some of the pieces are bent a little or whatnot and need massaging to fit right. Every part and fastener is getting cleaned and oiled, (if applicable), I just do it the exact same way as if it was my own and I know how I want it done.
And I agree that something is either "right" or it's not. You and I could rebuild a car or bike together and get along fine. I'm completely deranged with automotive/mechanical OCD.
Denis
Old 02-11-2011, 06:48 PM
lm6y's Avatar
I'm just happy to see that he fixed the old parts. We have all gotten it into our heads that we live in a disposable society, and it's better to chuck something, and buy new ones. Those old, tough S.O.B.'s that we admire here from time to time wouldn't buy a new part unless they screwed with it for a week, and mangled it beyond recognition. Nice to see that spirit is still alive and well in some of us.
Brent
Early85 944
LM6Y Paint Code
Old 02-11-2011, 06:53 PM
MAGA
I have been known to blow a whole weekend making/fixing a $50 part... I am addicted to the feeling of satisfaction from making something old and broken work like new again.
0% Liberal
Old 02-12-2011, 06:04 AM
lm6y's Avatar
I do the same thing. I'm just too damned hard headed or stubborn, or both to admit defeat. I call it "tinkering" or my hobby. But I've also learned a lot over the years. I walk the aisles at the hardware store every once in a while taking mental notes on things I can use as tools, or substitute parts later down the road. But none of these things were designed to do what I intend to use them for! I think it's a sickness.
Brent
Early85 944
LM6Y Paint Code
Old 02-12-2011, 06:36 AM
