canna change law physics
red-beard's Avatar
Mixed network components
Most of the stuff on my network is now 1Gbps. There are a couple of remenants that are 100Mbps. Using the switches, I can see which components (Old NAS, Dell Printer and both Wireless N routers!!!). Should I segregate these items?
If I have 4 items on a switch and one is 100Mbps, will it slow the whole switch down or just access to the 100Mbps item?
James
Red-beard for President, 2020
Old 02-14-2011, 07:26 AM
Paul_Heery's Avatar
If your switch is built according to the IEEE 802.3-2008 standard, it shouldn't be a problem. The ports on the switch will negotiate according to what is attached. It would not slow down the whole switch.
Old 02-14-2011, 07:36 AM
It certainly wouldn't bother a Cisco switch. Only the ports that connect to those older devices should be slower, and therefore only comms to/from those devices. Everything else should be speedy.
Old 02-14-2011, 08:23 AM
Scott R's Avatar
Yea, no reason to do anything. Besides 100mb is still perfectly fine for a lot of things. Mix away.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-14-2011, 08:58 AM
red-beard's Avatar
I was more thinking of segregating them on a single switch.
I was pretty surprised to see that the wireless-N routers had 100Mbps wired ports. I guess I need to switch those out too.
James
Old 02-14-2011, 09:11 AM
Scott R's Avatar
I guess, most n-routers from 10 feet are around 400MB on a good day. I would be surprised if you're touching that level of traffic internally. For the bulk of what most people do the choke point is going to be your external connection.
If you're always moving large files internally then you can get some benefit from 1gb. Most of the company I work for the end user segments are 100mbs still. When I worked for IBM most of our buildings were still 10mb and things functioned fine.
The data centers are all moving to 10GigE, but it's damned expensive right now.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-14-2011, 09:31 AM
red-beard's Avatar
Scott,
I just wanted to make sure that these switches wouldn't drop in overall speed due to older stuff being connected. As I've been trying to get my network moved over to 1Gbps, I keep finding recent stuff I've purchased (Dell Printer and the Linksys "n" routers), which I thought was 1Gps turned out to be 100Mbps.
Some time late this year or early next year, I'll be sorting out an office network.
James
Old 02-14-2011, 09:46 AM
Scott R's Avatar
Originally Posted by red-beard View Post
Scott,
You're good then. Only the ports that require the lower speed are restricted to it. The switch will take care of all that for you.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-14-2011, 09:57 AM
