Calling Shaun 84 Targa.... Silk screen help.
Shaun,
I hope you can help out. It's getting near the time for my guitar project to do a little silk screening to remain period correct. I doubt I can outsource this, as no shop will touch a registered trademark. Since this guitar is for myself and not for sale, I am not bound by trademarks. I looked online a few weeks back on DIY silk screening and found some info, but would like to know how you would go about it and if the results would be satisfactory. This is pretty much a one off deal, but I'd still like to do it right and probably would keep the screen in case I build another LP down the line. Any links, videos, advice would be greatly appreciated! Dave 1959 Les Paul guitar build...
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Hi Dave,
I started reading your epic thread (WOW, crazy impressive!) but can you tell me exactly what you want done? Is it something I can do for you and send? LMK!
Tru6 Restoration & Design |
Licensed User
Probably something like this:
Dave, I can burn a screen for you no problem, just need the artwork. do you know if that's screened directly onto the wood or fabric which is laid down and then poly'd over?
Shuie, yes, exactly! Also, is the Gibson logo a silk screen on a '59 or inlay?
Shaun, screened directly to the wood (actually on top of the lacquer). Gotta work on getting good artwork for it.
Licensed User
FWIW, here's a shot under a blacklight. Silkscreen appears to be on top of the nitro lacquer (no poly). This is a junior, not a standard, but either way, the 'Gibson' script should be under the lacquer. The Gibson script is a mother of pearl inlay on a Standard. The peghead veneer would be holly. The lacquer is old school nitrocellulose sprayed as thin as possible.
OK, just email me the artwork and I'll make you a screen. Do you know what ink you are using? I'm assuming UV cure, but please check.
Shaun, will do and I have no idea on the ink.
What do you recommend?Shuie, either I make the inlay or I think it may be hard to come by.. Not having much luck on the Google search yet.
Un-Registered User
Don 1988 Targa |
Un-Registered User
Don 1988 Targa |
I will research it Dave. I use heat to cure my inks which would not work in this application. I'll let you know.
Thanks, Shaun.
This thread talks mostly about the Junior, but I think the Standard got the same treatment.
Licensed User
Im pretty sure the silk screen goes over the lacquer and the 'Gibson' inlay goes under. I may be wrong, tho. It wouldn't be the first time today.
This isn't my work, just some photos I found on the interweb.
The "Les Paul model" was definitely silk screen and on top of the lacquer. That's why it's so easy to rub off when cleaning. It's the "Gibson" logo that is throwing me. After more reading, it seems that the Junior had a decal "Gibson" logo after the first clear coat, now it does look like the Standard is MOP. The logo looks gold these days due to the lacquer yellowing. I also think that the original Standards had the inlay route done around each letter. Later, it was done with the logo set into a black epoxy, then a rough rectangle was routed out, like in the above pix.
Dave, I could cut a vinyl stencil, you could apply that, paint the logo, and pull the vinyl...
Wouldn't require you shipping parts all the way across country. |
Thanks Sidney, but it has to be a silk screen.
Somethings have to be done right and vintage.
MAGA
Painting it on using a mask is no different then squeeging the paint on through a silkscreen IMO. Silkscreening is simply a way for the factory to do a bunch of these in less time.... just my two cents
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Un-Registered User
You apparently don't have the level of OCD that we do. I once heard of a guy that went to the trouble of modifying a sewing machine just so he could get the right number of stitches per inch while he made 'period correct' seat covers. When you're invested this deep, you just want things a certain way.
Don 1988 Targa |
