The Unsettler
dBA (noise) question
OK, lets say I have a device that has fans and the decibel level is 66.
If I replace the current fans with two rated at 36 dBA what's worst case total dBA. In theory if they are in sync I could end up with 72 dBA total? Or theoretically I could hang a fan speed controller on one and get them out of phase so they cancel each other out? Educamate me.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
39 dB
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
canna change law physics
David is correct
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Detached Member
39, yes. Sound pressure/level doubles for a little less than every 3 dB increase.
Hugh |
The Unsettler
Serious?
Thanks. Second question I just thought of, do dB's rise linear or logarithmic? Is 60 dB twice as loud as 30?
The Unsettler
Love this board. So 66 is way louder than 39.
Detached Member
66 dB isn't all that loud. The 8-hour worker Time Weighted Average (TWA) allowable by OSHA is 90dB, but with an action level where if you're exposed to 85 and above (which is less than 1/2 of 90dB) then the employer has to test your hearing annually and take administrative control, such as sound deadening, and personal protective equipment (ear plugs or muffs) and make sure year-to-year your hearing doesn't experience a "threshold shift" at different frequencies.
If you have an iPhone download the app "DJ app" or "Paul Von dyk" it has a crude but useful soundlevel meter and a frequency meter.
Hugh Last edited by Hugh R; 03-03-2011 at 05:29 PM.. |
For computer equipment, 66 db is like a chainsaw...
65 is an electric hand mixer Dishwasher 50-53 A quiet office 20-30
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 Last edited by red-beard; 03-03-2011 at 04:51 PM.. |
The Unsettler
It's a dual Xenon 1U so yeah that fkr is loud. Making me nuts. Problem is there is no where to hide it in the house. Looking at some fan alternatives. Hate to have to pick up a board in ATX and swap everything over to a different case. |
Un-Registered User
My honda EU3000iS generator runs between 49-58 dBA.
Don 1988 Targa |
AutoBahned
dB - not db or DB or Db
the reason is that the B means a Bell and the d means deci- yes it's a log scale there is likely a real pretty graph with icons for various examples on the internet somewhere it may have more annoyance impact than the increment from 36 to 39 tho - depends on location of listener & source + any reflective or absorptive surfaces in the area (not to mention standing waves) |
Not exactly. In acoustic/audio applications, a 3db increase only represents a doubling of the power. Twice the sound pressure level is closer to 6db. Twice the perceived "loudness" (volume) is actually closer to 10db.
The CPU fan and the video fans are what I can't change...Well, I can change the CPU fan, but they are expensive! I can switch off the cooling control and let the fans spin up and the difference is huge.
Detached Member
Eric I believe you're correct. I'm a little rusty on the subject and used the terms interchangeably which is incorrect.
Hugh |
AutoBahned
I'll start a computer case fans thread...
Used Up User
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
The Unsettler
8 of those little bullet fans, 4 rows of 2.
![]() This is the best replacement option I've found. Would require 2 of them. Thermaltake 1U Intel Xeon Server Solution 1U Active Solution Copper CPU Cooler for Socket 604: A1934 (Retail)
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 03-03-2011 at 08:59 PM.. |
Yup, those 1U cases with those things are brutal.
If it's an OEM box, they are probably only running at half speed too. I know my HPs spin up to full (and deafening) and then throttle down to half once the test is done. This way they know they can kick up to double if one dies. And you'd know it as soon as they did.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
This is the graph they use for my son.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
The Unsettler
