AutoBahned
RWebb's Avatar
Tooth crown & "Numbing" Query
a crown on a molar popped off (on Friday of course)
My dentist will see me very late on Tuesday to put it back.
BUT, Tuesday is Mardi Gras! And I have some drunken revelry scheduled, starting at 6:30 - said revelry also includes a lot of great food...
SO I want to get a handle on whether he is likely to use anything that will interfere with my sense of taste ("numbing"; local aenaesthesia) OR will interact with alcohol fueled fun and trying to drive home much later ....
crown is Gold; and the tooth doesn't hurt
Trying to assess the probability that he will just do a quick cleaning, antiseptic and then reglue it as vs. something more major.
I find a lot of 'stuff' posted on the Internet of course - but it is mostly about which wax to buy for a temporary repair
Nor will his receptionist be of much help...
Any thoughts?
Old 03-07-2011, 10:45 AM
doubt he will work on you if your toasted..
most likely he will clean it up a bit..
test for fit..
if good..some clue and of you go..
Rika
Old 03-07-2011, 12:14 PM
wdfifteen's Avatar
Any thoughts?
My experience - if the crown comes off and it's off for a while they have to start over. If you immediately stick it back on with Fix-O-Dent until you get to the dentist it's possible to do a clean and re-glue.
Old 03-07-2011, 12:30 PM
Take a look at the crown and the tooth. Does everything look mostly clean? If there is plenty of decay, either in the crown or on the tooth, it may not be good enough to recement. Try to keep the crown back on the tooth also. Your teeth will shift slightly making it harder to just recement. You shouldn't need anesthesia either. If your plans are going to interfere, just tell him to cement it on temporarily if it needs to be replaced. Trust me, Dentist want to get out of work on time also, so they are more then happy to get things done and go home.
Old 03-07-2011, 01:05 PM
Zeke's Avatar
Mardi Gras is more important than your teeth.
Old 03-07-2011, 01:17 PM
AutoBahned
RWebb's Avatar
thx - I'll just go in & not move the appt.
BTW - it is dark - but thought that was the cement
re "Dentist want to get out of work on time" -- had some fun conversation re that at the bar Fri & Sat with a surgeon & an ER doc
Old 03-07-2011, 01:35 PM
Band.
Is it a root canal tooth? Or crown only?
If it's a root canal tooth he will just clean it up and reglue it. If it's a regular tooth, he will check for decay and probably just re glue it. If more decay, he will recommend a root canal or a fresh appt to re-post and reglue it.
Old 03-07-2011, 01:38 PM
AutoBahned
RWebb's Avatar
dunno - I let the dentist keep the teeth records...
guess I'll find out tho
Old 03-07-2011, 02:37 PM
Immature Member
dentist90's Avatar
89911 and Gogar are on the right track. If the tooth is root canal treated you can clean the tooth up without concern for sensitivity... even remove decay if necessary. If you're in a rush, just ask him how it looks and if he feels it needs more attention (ie: freezing) ask him to put it back on temporarily for now.
Enjoy the party, Brah! (rhymes with mardi gras)
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 03-07-2011, 03:15 PM
AutoBahned
RWebb's Avatar
Thanks!
Old 03-07-2011, 03:26 PM
Senior Member
test for fit..
Rika
Rwebb has not been normal for years now, so if the dentist took him before, well he will prolly just gas him up and get to work...
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 03-07-2011, 08:12 PM
DanielDudley's Avatar
Originally Posted by milt View Post
mardi gras is more important than your teeth.
lol ! :d
Old 03-08-2011, 01:42 AM
