AutoBahned
RWebb's Avatar
treating a rusty ol' tailpipe, runners, etc.
not on the Pooschey, but I'd like to make the exhaust on my VW Vanagon last as long as I can
is the stuff that Eastwood makes better than the paint I can buy OTC?
if I don't use the Eastwood stuff, I plan to just sand a bit and then either use Rustoleum primer & paint or use a rust reduced as primer
thoughts?
Old 03-04-2011, 01:57 PM
fastfredracing's Avatar
If you are talking about what eastwood calls "manifold dressing" IT works very well. I used it many times on cast iron exhaust manifolds, and even used it several times on steel headers. It holds well. I have even used it on old rusty heat exchangers that I sandblasted first, and it also retained its color and adhered well.
No left turn un stoned
Old 03-04-2011, 02:04 PM
AutoBahned
RWebb's Avatar
thx - yes, the manifold dressing
you like that better than Rustoleum?
do you put a primer on first?
Old 03-04-2011, 04:20 PM
wdfifteen's Avatar
Calyx manifold dressing is a lot easier to use than any paint and it works better than any paint I've ever tried.
Home
Old 03-04-2011, 05:15 PM
19 years and 17k posts...
azasadny's Avatar
Eastwood's products cannot really be compared to Rustoleum, they are THAT much better! Wuerth also makes a heat resistant paint that works well, but the Eastwood manifold paint is better, I've tried all of them...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 03-04-2011, 05:40 PM
AutoBahned
RWebb's Avatar
thanks!
sounds like Eastwood just sells the Calyx dressing, so I might be able to find it locally and avoid shipping (?)
know if any parts chains carry it?
Old 03-05-2011, 12:55 PM
wdfifteen's Avatar
thanks!
Get it straight from George. He's a nice guy and his price is better than Eastwood's.
Old 03-05-2011, 06:33 PM
Registered lurker
red911sc's Avatar
Sounds like you best see one of them there proctologists if'n you's got a rusty tailpipe with runners...
Jeff
'79 Widebody SC
Old 03-05-2011, 08:13 PM
wdfifteen's Avatar
I found the container of Calyx I had left over from doing my truck. It took about half a teaspoon to do this manifold. I painted the header pipe because it runs cool enough that it doesn't burn off high temp paint. I have to redo my manifold because I got the Calyx too thick in some spots and it popped off. If you want, I'll send you what I have after I take out enough to redo the manifold. PM me if you're interested.
Old 03-07-2011, 08:16 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Por-20
Black Cars Matter
Old 03-07-2011, 08:30 AM
wdfifteen's Avatar
Randy,
The lost container of Calyx has been, found, relost and finally refound and is on its way to you.
Old 03-14-2011, 05:59 AM
AutoBahned
RWebb's Avatar
Thanks!
Old 03-14-2011, 11:03 AM
