Any locksmiths? How do I re-key my ignition switch?
1991 318is.
I got the cylinder out of the ignition switch and took it to my locksmith, but they couldn't figure out how to remove the tumbler portion out of the cylinder. Anybody know how to seperate the two so I can re-key it so I have one key? BTW. Called the dealer and he didn't know anyone who could do it or get a keyed cylinder. Said I need to change ALL the door/trunk locks to match the ignition...
canna change law physics
There is actually FAQ on this in the tech pages, at least for the early Porsches.
Pelican Technical Article: Rekeying Porsche Locks
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Thinking about it some more, would the dealer be able to get me an ignition cylinder/switch keyed to the car/VIN?
A locksmith can set the ignition to match the doors/trunk. It's under $100, usually.
I love you guys outside this forum ![]() -Eric |
If I'm not clear, find a junk yard with similar car and get the full set of locks!
OMG! Two keys?!?!
I must be OCD to want one key on the keyring I guess. Before I go the route of changing all the locks or two keys, I'll see what my other options are, but there has to be a way to rekey the ignition switch. I've done it on other cars. Called the dealer again and he said he could get it this time with proof of ownership. Same guy I talked to earlier, so I don't know why it's different now. I'll see when I get there if we are on the same page. Last edited by A930Rocket; 03-14-2011 at 02:35 PM.. |
I can buy a new or used set for the entire car, I'm just trying to save a buck and some time.
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I made up a comprehensive and ignored post about the ignition switch a long while ago - I attacked it to fix the problem of it not allowing a consistant start or restart - the restart prevention function was overactive. Still working well after four years.
The post contains info on rekeying the ignition switch. IN A 911 ------ Ignition switch thread pictures
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon Last edited by notmytarga; 03-15-2011 at 12:19 AM.. Reason: Ah hell - not a 911 |
I should've clarified - the new locks were because individually the ignition, and then the driver's door lock wore out and would no longer turn. With the VIN they were able to make a new one that fit the existing keys/other locks. Same thing when her key finally wore out.
'87 924S (Sold) |
