Hendog's Avatar
Ms-dos 6.22
In the world of radio communications, you often have very old technonlogy that is still "out there" and runing. Currently I have a Motorola application which logs system usage. It's running on a very old machine. It's DOS based.
The machine is running MS-DOS 6.22. What command would I enter to find out which vintage (speed) of processor it has? I think it's a 386 but don't know for sure. Thanks for the help
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 04-25-2011, 08:17 AM
Banned
I dont know why motorola wont update anything. Try to program a GM300 or the like. There are still a ton of them out there in use.
Old 04-25-2011, 08:24 AM
id10t's Avatar
Check the bios when it boots.
Old 04-25-2011, 08:25 AM
VincentVega's Avatar
'msd' gives cpu info
Old 04-25-2011, 08:28 AM
It has been a while since I used DOS but I don't think there is a command for that. You call it is system, I presume it is a computer. When you reboot it the BIOS shows for a shot period. To get into the bios you will have to hit the del or F1 or some other function key. It may well have a prompt like hit F2 for system or some such.
Once you get into the BIOS it will identify the CPU & the memory. Just poke around. Be sure NOT to save any changes when you exit BIOS unless you are real sure you want to change something.
Edit: I forgot about MSD.
I still have a Microst Software Box with a set of DOS 6.22 floppies sitting on the shelf in my closet at home. I even have my Compac DOS 2.1 system floppies.
Old 04-25-2011, 08:29 AM
Hendog's Avatar
The machine is running. I don't want to shut it down; I'm afraid it might not come back up therefore the question.
Henri
Old 04-25-2011, 08:37 AM
Hendog's Avatar
There's no money it it for Moto to do that. They prefer to sell you new stuff.
Henri
Old 04-25-2011, 08:38 AM
No way to crack open the case and have a peek inside without shutting it down?
'87 924S (Sold)
Old 04-25-2011, 11:36 AM
canna change law physics
red-beard's Avatar
My first laptop, still have it, has 6.22 on it. I had to manually load it on there, as the internal diskette was only a 720K.
James
Red-beard for President, 2020
Old 04-25-2011, 11:40 AM
Yes MSD is the command , but if the processor is newer it probably won't tell you to much.
1987 Carrera
Old 04-25-2011, 12:52 PM
