rnln's Avatar
question on drilling into tiles.
Hi guys,
Anyone who ever installed a bath tub slide door, may I ask a question on drilling on the tiles? Do I just drill directly into the tiles, to screw in the slide door's aluminum frame, or is there a special tool/technique?
Thanks.
Fat butt 911, 1987
Old 04-08-2011, 12:19 PM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
They have tile bits and i always put masking tape on the tile, mark the hole then drill. The tape is less slippery than the tile.
Old 04-08-2011, 12:22 PM
GEt a tile drill bit at your local tile shop for a few bucks. I sometime use a cheap glass drill bit if its just a couple of holes.
Old 04-08-2011, 12:30 PM
rnln's Avatar
Is the tile dril bit same as concrete drill bit?
Fat butt 911, 1987
Old 04-08-2011, 12:34 PM
No. Go to the store and look around.
Old 04-08-2011, 01:34 PM
Zeke's Avatar
It always helps to use a center punch on the location of the hole. You don't need to hit it hard, just break the surface. The drill bit will stay right there. I use common masonry bits. Haven't cracked a tile yet.
Old 04-08-2011, 01:58 PM
fastfredracing's Avatar
Buy a couple of bits as well, they can snap pretty easy if they bind in the hole.
No left turn un stoned
Old 04-08-2011, 02:03 PM
A930Rocket's Avatar
Drill in the grout line if you can. Saves a lot if time and trouble.
Old 04-08-2011, 03:36 PM
Lowes and Home Depot will have the tile bits.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 04-11-2011, 08:23 PM
Control Group
Tobra's Avatar
Trekkor?
Old 04-11-2011, 08:25 PM
JW Apostate
trekkor's Avatar
This is the way to do it.
Good advice!
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 04-11-2011, 08:41 PM
rnln's Avatar
Thanks everyone. I did a search for "Masonry bits" and found this picture below, and also found that my dad has one from years ago in his tool box.
Thanks again.
Fat butt 911, 1987
Old 04-14-2011, 11:12 AM
You do not have permissi
john70t's Avatar
4ft level is your friend.
Clean and scrape first. Install very dry first to check fitment, then work fast.
Continuous even bead of clear silicone under the inner edges, and wrap it up sides. Finish with matching silicone caulk. Blue tape a stop line if caulking skilz ain't perfect(like mine).
The plastic inserts with bumps hammered in will have some give, and don't spin with proper drill size. Glueing them in place first is even better.
Old 04-14-2011, 11:58 AM
Driver
Noah930's Avatar
I recently installed some fixtures in my bathroom, and drilled through various ceramic tiles. I was always told to go slowly, to avoid heating up the tip of the drill bit too much, and to apply a constant stream of water/oil to cool off the tip. What a waste of time, that advice. You'll be drilling for years.
I finally googled "drilling through ceramic tile." There are a couple videos out there. I bought a couple masonry bits. Pretty much drill slowly for a few (3 or 4) short bursts to break the glaze on the tile surface. Masking tape on the drill site helps keep the bit from walking initially. And then drill away with wild abandon (and ignore all the admonitions to go slowly). Done in about 15 seconds.
1990 Black 964 C2 Targa
Old 04-14-2011, 02:30 PM
Unregistered
sammyg2's Avatar
That's the same way I do it.
Put some tape on it, mark it, then carefully and softly tap it with a hammer/center punch until I break up the thin glaze covering. Then drill like it's going out of style with a carbide tipped masonry bit.
Just don't tell let the masons here you say that, it's 'sposed to be a secret!
Old 04-14-2011, 06:20 PM
