LinkBack | Thread Tools | Rate Thread |
long shot: anyone here successfully DIY spark plug change in Subie forester XT?
we are approaching 60k miles. spark plug time. i figured out which plugs to get..all the forum say that it is absolute hell getting to them.
i took a peek yesterday. holykrap! the coil packs ontop of the plugs are a mere 1.5" from the body work of the car!! both sides! i've seen tight spaces, but this is ridiculous. so we are clear. 2005 subaru forester XT, (turbo 2.5L) anyone do this? for sure i have to take out the airbox on one side and the washer fluid reservoir on the other side..minimum. minimun.
poof! gone |
(cue the ubiquitous lesbian Forester poster..in 5, 4, 3......)
poof! gone |
I've got the 3.0 but this here should be almost the same for your Forester (with pics). Shouldn't be tough for you Cliff.
2002 OBW Spark Plug Replacement - Subaru Outback - Subaru Outback Forums
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
thanks..didnt find that particular thread.
damn, they lifted the motor!
poof! gone |
Pain in the ass. Best way I've found is to remove the lower motor mount and slack the tops. Then jack the engine up a bit with a block and you can get to them quickly. Otherwise you're in for a few hours, a lot of swearing, and a bunch of little extensions and swivels.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
craig..the non-turbo motor looks easy. the turbo one..they are lifting the motor!!
poof! gone |
what would the Subie stealer charge for this service..
Rika |
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
i have an engine crane that you can borrow
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
Did you get the memo?
What Scott said. I did plugs in my '05 Legacy GT, it was an SOB but doable. I had to rotate several of the coil packs and remove them at an angle, and the extensions have to be small and inserted one at a time. It was a good solid 2 hours for 4 stupid plugs. Stock up on beer.
Navin Johnson
Just did the plugs in my 08 WRX a month or so ago. A bit of a pain, but you do not have to do anything like loosening motor mounts and jacking the motor up...
I don't know how similar the engine bays are for the 05 2.5 XT turbo, and the 08 WRX (also a turbo) but I bet they share some basic similarities. You will need to work from above and below, removing the battery and the air filter assembly is very helpful, get the car up on ramps or jack stands, remove the under tray.. viola Remove the harness from the coil packs, you need to spin some of the coil packs to remove them, remove plug, replace plug/coil pack/reconnect wiring... rinse and repeat.. Schedule the plug replacement to coincide with an oil change, kill two birds etc.. I didn't time myself when I performed the plug change/oil change/clean and top up the battery/ etc... but I bet I was all buttoned up in about two hours..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Parrothead member
Here ya go Cliff...
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
