vash's Avatar
long shot: anyone here successfully DIY spark plug change in Subie forester XT?
we are approaching 60k miles. spark plug time. i figured out which plugs to get..all the forum say that it is absolute hell getting to them.
i took a peek yesterday. holykrap! the coil packs ontop of the plugs are a mere 1.5" from the body work of the car!! both sides!
i've seen tight spaces, but this is ridiculous. so we are clear. 2005 subaru forester XT, (turbo 2.5L)
anyone do this? for sure i have to take out the airbox on one side and the washer fluid reservoir on the other side..minimum. minimun.
poof! gone
Old 04-27-2011, 01:48 PM
vash's Avatar
(cue the ubiquitous lesbian Forester poster..in 5, 4, 3......)
poof! gone
Old 04-27-2011, 01:49 PM
craigster59's Avatar
I've got the 3.0 but this here should be almost the same for your Forester (with pics). Shouldn't be tough for you Cliff.
2002 OBW Spark Plug Replacement - Subaru Outback - Subaru Outback Forums
Old 04-27-2011, 02:00 PM
vash's Avatar
thanks..didnt find that particular thread.
damn, they lifted the motor!
poof! gone
Old 04-27-2011, 02:08 PM
Scott R's Avatar
Pain in the ass. Best way I've found is to remove the lower motor mount and slack the tops. Then jack the engine up a bit with a block and you can get to them quickly. Otherwise you're in for a few hours, a lot of swearing, and a bunch of little extensions and swivels.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-27-2011, 02:09 PM
vash's Avatar
craig..the non-turbo motor looks easy. the turbo one..they are lifting the motor!!
poof! gone
Old 04-27-2011, 02:10 PM
what would the Subie stealer charge for this service..
Rika
Old 04-27-2011, 02:12 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
i have an engine crane that you can borrow
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 04-27-2011, 11:27 PM
Did you get the memo?
onewhippedpuppy's Avatar
What Scott said. I did plugs in my '05 Legacy GT, it was an SOB but doable. I had to rotate several of the coil packs and remove them at an angle, and the extensions have to be small and inserted one at a time. It was a good solid 2 hours for 4 stupid plugs. Stock up on beer.
Old 04-28-2011, 04:47 AM
Navin Johnson
TimT's Avatar
Just did the plugs in my 08 WRX a month or so ago. A bit of a pain, but you do not have to do anything like loosening motor mounts and jacking the motor up...
I don't know how similar the engine bays are for the 05 2.5 XT turbo, and the 08 WRX (also a turbo) but I bet they share some basic similarities.
You will need to work from above and below, removing the battery and the air filter assembly is very helpful, get the car up on ramps or jack stands, remove the under tray.. viola
Remove the harness from the coil packs, you need to spin some of the coil packs to remove them, remove plug, replace plug/coil pack/reconnect wiring...
rinse and repeat..
Schedule the plug replacement to coincide with an oil change, kill two birds etc..
I didn't time myself when I performed the plug change/oil change/clean and top up the battery/ etc... but I bet I was all buttoned up in about two hours..
'69 911 GT-5
'75 914 GT-3
and others
Old 04-28-2011, 05:13 PM
Parrothead member
VINMAN's Avatar
Here ya go Cliff...
Vinny
Old 04-28-2011, 07:00 PM
