winter-hater club member
nynor's Avatar
open it up and look at the fan on the CPU to verify it is spinning. if you are booted now, it is spinning. i think i set mine for auto shutdown at 55C. maybe 60C.
also, check the connections on the CPU fan lead. and spin it by hand to make sure it isn't binding, not even a LITTLE BIT.
how does your firefox look now?
"COOL PRIUS!" - Nobody Ever
Old 05-19-2011, 11:26 AM
AutoBahned
RWebb's Avatar
looks fine now
I guarantee it is now and always has been spinning. The fan is so damn loud I have trouble hearing on speakerphone...
Old 05-19-2011, 11:29 AM
jeffgrant's Avatar
ok, so why does the system frequently fail to boot up now?
sometimes it will not even go past the very first BIOS screen
Karma for your recent post flood?
Old 05-19-2011, 11:30 AM
nynor's Avatar
if it is that loud, i'd be willing to bet it is having problems.
jeffgrant's Avatar
How dusty is the inside of the box? Might want to consider taking some pressurized air to the inside to get the dust off of everything.
Dust is a major problem, as it can cause things to get really, really hot, regardless of air flow through the box.
Old 05-19-2011, 11:32 AM
nynor's Avatar
and don't use a vacuum. my experience with using a vacuum cleaner on a PC was VERY bad.
Old 05-19-2011, 11:33 AM
AutoBahned
RWebb's Avatar
it has been that loud since new
it is only 4 months old - if it builds up dust related problems this fast, I need to throw it away
the Dell XP system lasted 3 years in a dustier environment - no problems
I also checked into a MAc Mini - not enuff HDD space on it, so I'd have to pay $1,500 for an iMac, which the Apple sales guy said would be comparable in power to a Dell 8300 XPS system.
Old 05-19-2011, 11:46 AM
Burn the fire.
Brando's Avatar
Could be a bad stick of memory.
It may take a while, but try this route -> Memtest86.com - Memory Diagnostic
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-19-2011, 11:48 AM
nynor's Avatar
~shrug~ possibly the fan has been bad since new....
Old 05-19-2011, 11:49 AM
AutoBahned
RWebb's Avatar
fan works fine tho noisy - it might be undersized
Old 05-19-2011, 01:01 PM
