-   -   One point!! Failed by ONE point (http://forums.pelicanparts.com/off-topic-discussions/612955-one-point-failed-one-point.html)
KevinP73 06-08-2011 12:20 PM
Effin smog nazis failed my truck for being one friggen point over the limit. I just rebuilt the engine, it's running perfect but at 25mph it emits 35 HCs instead of 34. How pissed am I?
cgarr 06-08-2011 12:44 PM
How accurate is their equipment?
stomachmonkey 06-08-2011 12:55 PM
Run the tank as low as you can, add a couple bottles of dry gas then put in only enough premium as needed to get it to the inspection station and run the tests. Idea is to get it to run on as much alcohol as you can.
Friend of mine who owns a shop told me that a bunch of years back when my car failed, worked like a charm.
fingpilot 06-08-2011 12:59 PM
Get a haircut before going in to the test station.
s_morrison57 06-08-2011 01:01 PM
close only counts in hand grenades
sammyg2 06-08-2011 01:05 PM
Regular unleaded gas burns cleaner than premium during smog tests ................
GH85Carrera 06-08-2011 01:57 PM
Would it make you feel better if you failed by several points?
widebody911 06-08-2011 01:58 PM
& horsehoes
GH85Carrera 06-08-2011 02:01 PM
Originally Posted by widebody911 (Post 6068873)
& horsehoes
and atom bombs.
kach22i 06-08-2011 02:11 PM
Really?
Are you sure?
krystar 06-08-2011 02:28 PM
...u still have sniffer emissions?
run some e85 in there.
HardDrive 06-08-2011 03:23 PM
As we speak, a guy in India is throwing a ball of plastic bags on a fire to keep warm. Oh wait, make that 1,000,000 guys.
Tobra 06-08-2011 03:39 PM
Originally Posted by GH85Carrera (Post 6068881)
and atom bombs.
and government works
if the coil or distributor is a bit tired, you can get elevated HC on the sniffer, seen old plug wires do that too
You could always just pretend you only speak Spanish and don't have any license, insurance or registration, then they would just let you go. What color are your eyes and hair?
juanbenae 06-08-2011 03:43 PM
Originally Posted by kach22i (Post 6068899)
Really?
Are you sure?
yeah, thats what ive heard. the higher octane takes more heat to burn effective like so easier burn less do-do with lower octane.
bell 06-08-2011 04:44 PM
maybe the problem isn't the truck but the state you live in.........
johnsjmc 06-08-2011 04:44 PM
High HCss can be caused by fuel contaminated engine oil. .A rebuilt engine often lets more fuel past it,s unseated rings and add some fuel to the oil. The PCV system will suck up the fumes and increase unburned HC in the tailpipe. Small amounts can make enough difference to fail . A good long hot highway run will burn off most as will an oil change (smell the dipstick and change the oil if you smell any fuel).
Timing off a couple deg. either way will also affect HC.
If your HC was high caused by timing then your NOx would likely be on the low end of acceptable.
johnsjmc 06-08-2011 04:47 PM
Florida should bring back etesting. I have a winter home in Tarpon Springs Fl. Florida has more than it,s fair share of "stinky" old cars.
Tobra 06-08-2011 05:04 PM
It may not pass until after your first oil change if motor is freshly rebuilt
bell 06-08-2011 05:12 PM
i have to saw i see a hell of alot LESS smokey/smelly cars in florida than the previous 30 years in ohio.....who has e-check.......what does canada test for?
johnsjmc 06-08-2011 05:23 PM
Ontario tests vehicles on a dyno at idle and 25mph . Sniffs 3 gases HC,Nox and CO Plus gas tank cap seal is verified.Exhaust systems are supposed to be leakfree to be able to be tested. Vehicles are tested every other year . No testing on pre 1988 cars but catalysts and other equipment can,t legally be removed /disabled. A gross polluter (oil burner cloud) can be stopped by the police and ordered off the road until repaired but that seldom happens. There is a $400 repair limit for a failed car.Taxis and commercial are also tested but there is no cap on repair costs.. There are fewer old cars still on the road here than Florida as our cars are subjected to winter road salt.Some norther counties are not tested presumably because of small numbers of cars. More travel by snowmobile you know
