Problem with reformatting a 2006 iMac
I'm helping a friend revitalize an older iMac. Trouble is he doesn't remember the password and we've been locked out a few times trying various possibilities.
I've tried erase the drive with Disk Utility, but the drive is greyed out, not selectable. it also won't let me erase/install with a new iMac install disk selected as the start-up. Any ideas? I want to erase the drive and do a fresh install with a copy of Snow Leopard.
Tru6 Restoration & Design |
The Unsettler
You can reset the password from the installer disk.
Boot from CD, go thru the couple of steps until you see the menu items pop up along the top. From there you can select reset password. But that should not prevent a clean wipe install when booted from the CD. When you boot with CD in hold the C key to force it to start from the installer disc. Scott EDIT: You sure it's an Intel box and not a late PPC chipped box? Snow Leopard does not support PPC chipset.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 07-15-2011 at 01:09 PM.. |
I have an older version of OSX, bought a family pack for the office. Thank you!
The Unsettler
It will take Leopard just fine.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
And quite a few different Linux distributions
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
