Jim Bremner's Avatar
BEE swarm.
Other than off'en 'em is there any thoughts how to convince them to leave?
They're in a cinder block wall. There's a pair of 3/8" holes that's missing bolts to hold a extension that's missing.
There's another 2" diameter hole 3 rows down. I've put burning newspaper in but it hasn't sent them away
Old 08-10-2011, 06:46 PM
pwd72s's Avatar
As your county agent for a list of beekeepers. One near you may want them, if it's a recent swarm.
Caulk the holes?
Old 08-10-2011, 06:51 PM
Banned
I had some nasty bees build a home in my house in Costa Rica, I had to kill them, all of them, used the same stuff we used on coackroaches, ants, spiders and leftists, stuff called BayGon. Got some on my arm as I was spraying into the hole, blistered it and looked bad, but killed the bees. Otherwise they weren't leaving.
I used to tape or wire a vacuum beside their entrance. Suck 'em up the tube then put the vacuum on the car muffler and let it idle for 10 minutes.
Then dump the carcasses in the trash. Done.
Old 08-10-2011, 06:59 PM
White and Nerdy
Tervuren's Avatar
My Dad solved the problem by getting small shot and a pistol - hit 'em when they are going in the hole.
Shadilay.
Old 08-10-2011, 07:10 PM
A930Rocket's Avatar
Kill it with fire:
Old 08-10-2011, 07:11 PM
Banned
could be tough with everclear.
Old 08-10-2011, 07:14 PM
pwd72s's Avatar
Sadly, I believe Baygon has been removed from available use in the USA...
Old 08-10-2011, 07:17 PM
entertaining the idea
UconnTim97's Avatar
Boric acid powder sprayed into the holes should work.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 08-10-2011, 08:02 PM
Max Sluiter
Flieger's Avatar
Smoke makes them leave the hive, that is why beekepers use it. If you could put some flaming newspaper in there, then close the entry way somehow- put a rock over it maybe?
Old 08-10-2011, 08:06 PM
slodave's Avatar
Smoke sedates them. Doesn't make them leave. Gives the bee keeper time to get the queen out without being swarmed. Also gives them time to inspect the hive..
Old 08-10-2011, 08:27 PM
Wood Magician
It's kind of silly and backwards to just kill them off- Unless they are hornets etc.
If honeybees then let a bee keeper/ bee person remove them for free as someone else mentioned.
I have run into this scenario a few times over the years and never had a problem getting someone to come pick them up free of charge.
Old 08-10-2011, 08:38 PM
Free Bees! come 'n get 'em!
Hell I'll buy you a BEER! if you do!
Old 08-10-2011, 08:42 PM
Student of the obvious
LeeH's Avatar
Had a swarm once. It was picked up free of charge. FYI - If you spray them with chemicals first then the beekeepers don't want them.
Lee
Old 08-10-2011, 09:04 PM
Crap! I just gave them some LSD, They're TRIPPING!
Old 08-10-2011, 09:12 PM
Run smooth, run fast
Heel n Toe's Avatar
Beekeepers are only interested if they're honey bees. Do you know if that's what you have?
You could have carpenter bees. Or hornets. Or maybe something else.
Can you post a photo?
- John
Old 08-10-2011, 09:23 PM
Heel n Toe's Avatar
BTW, just in case it's African Killer Bees, be careful.
Use a telephoto lens. Seriously.
- John
Old 08-10-2011, 09:24 PM
LeeH's Avatar
And have them sign a release.
Lee
Old 08-10-2011, 09:31 PM
crustychief's Avatar
My merlot has a slow finish when flowing out of my nose!
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-10-2011, 10:44 PM
disband
juanbenae's Avatar
burn some incense continuously at the entry point. it'll be groovy and they will think hippies moved in and get the hail out....
Old 08-11-2011, 08:59 AM
