Would like to build a man-cave.... costs?
I'd love to have a place to hang out and shine my newly purchased and restored motorbikes. Something sitting alongside my house here in Montana that would match it architecturally. I'm fairly DIY these days, so looking at having the shell constructed by a contractor, and I'll do the finish work inside (drywall, floors, ceiling, plumbing, electrical). This would be a simple, open approx. 22'x50' space with stubs for water only to plumb a toilet and sink (no shower). I can use a compact water heater under the vanity. No need for 240V or gas. I'll heat it on demand with a pellet stove. I have a septic sitting between the house and this building. Electric would probably have to have its own meter.
I was just reading on another motorcycle forum about how guys are throwing up shells for $15K-$20K. If that was the case, I'd be all over this, but I'm suspecting the cost will be much higher. Any rough ideas from any of you who've done something similar? Am I missing anything here? Ideas and input welcome, too ![]() A few mockups... 25 years ago I was at the forefront of architectural 3D technology, but nowadays I'm almost a MS Paint guy. ![]() I came across this restroom at the Rockefeller preserve in the Tetons last week. Its a close approximation of the shape I'm looking for. ![]() ![]() My home is a Lindal cedar home with post & beam construction. I want the toy house to match as closely as possible.
'95 993 C4 Cabriolet Bunch of motorcycles |
Motion,
The best website for your specific questions is here: The Garage Journal Board - Powered by vBulletin There are a few folks from here that post there as well. The Garage Gallery has some very similar structures to the one you are looking at. There is also a group called Geobarns that has an excellent website with some very nice designs. I have redone two tobacco barns here on the farm, added a workshop in one, etc. but that experience won't help much in Montana ![]() 15 to 20k for the shell doesn't seem out of line...
1996 FJ80. |
Somewhere in the Midwest
For reference, I semi-custom built 20x24 in the Chicago suburbs about 4 years ago. I had them do all the exterior work and some interior work. I ran electrical myself and was the general for the project. Total cost was about $15,000.
I purchased pre-made trusses and did all the permitting work, including the drawings for permit. Some municipalities don't require architectural and PE stamped drawings. You can permit it without the electrical and get the building contractor to just put up the shell. You can then go get the electrical permit. It's always a good idea to build a relationship with the inspector who will help you do it right, and give you time to fix what isn't right. They are more than willing to help if you are easy to work with. I'm sure you will do fine in that department. |
When I built my old shop, I tried to got the steel or timber "pole barn" route thinking it would save cost, but it really wasn't. There are carpenters out there that can quickly frame, roof and side the structure in a matter of days. And they can do it cheaply. I've been looking at pre-formed walls and structures for a guest house on the farm, but they are all more expensive than traditional stick build structures. The time savings is what you buy with those alternative constructions.
You should be able to track down a carpenter in your Monatana corner of the world who can put up the building for you and help you with the county permitting. I would guess your 22x50 building with the nice siding will be about $25000 without a lot of interior finish work. Let the carpenter frame the interior for you during the construction. It won't add much more to the cost of the building. If you can go wider, I would do it now. 22' won't be wide enough when you are done, believe me. My 60X100 barn seems small sometimes! Last edited by MotoSook; 08-11-2011 at 08:16 AM.. |
Almost Banned Once
How set are you on your design? What about a good old fashioned log cabin, widened for the garage space?
Just like the originals with concrete sealing the log joints. Part of the reason I'm suggesting this is because of cost. Not dry walling. IMO It would suit your property. You could DIY a log cabin. You just need good foundations or a slab. How expensive are good straight logs?
- Peter |
You should be able to talk to some people around your area to get an idea of a cost per square foot for something like that. Any reason for the 22 ft. depth? My preference would be for a slightly narrower building with more depth - maybe something like 25 or 30 X 40 to 45. My garage is 25 x 32, and although it's OK, I feel like more depth would give more flexibility in terms of moving & locating vehicles, equipment, etc.
Marv Evans '69 911E |
motion that would be awesome.
i would make one entire side open up to the mountain view.
poof! gone |
The picture below is of one of the tobacco barns I converted. It is 20' wide and 70' long. Very cramped from a width perspective, so much so that I'm going to enclose the remaining half and put a garage door in from the right end of the barn: Full size trucks need at least 25' to work on comfortably. ![]() Front view before the shop was put in.
1996 FJ80. Last edited by Seahawk; 08-11-2011 at 11:14 AM.. |
i'm just a cook
Ive been getting some bids for a shed myself. I am looking for a 22 X 34' with 12' tall walls. I also want a 10' overhang on one side. I got a bid of $21,000 for basically a pole barn with concrete floor. $30,000 for a metal building, and $40,000 for a 2x6 frame building with siding and asphalt roof. These were all unfinished on the inside. No electric, plumbing, or insulation.
I think I'll just wait, or do without.
2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 |
AutoBahned
find the thread of that guy in Wash. who built a garage - he posted step by step pics
a lot of the cost depends on how much of it you DIY - can you work concrete?? how are your framing carpentry skills? what tools do you have? I can tell you that I built a new wall on my house with a hammer, and I discovered why the nail gun was invented... do NOT neglect to lay hose for a hydronic heated floor before the pour! |
You do not have permissi
-Water heaters-on-demand might operate better on 220V, as they usually source from europe and japan. Pump pressure from the well might fluctuate during the year depending on local runoff and temperatures. Might affect this. Redundant water systems are never a waste of money when there is a houseful of dancers. -240V and/or gas is never a bad thing, if possible. That huge roof area would also hold loads of solar panels along with the 100year snow if the underlying structure is solid. Energy prices for either may change and you'll be able to use either. One incident of freezing up in the mountains during the winter will confrm this. -"Septic sitting between the house and this building". The septic should be on the downhill slope, below the well, period. Poop and drinking water don't mix. Last edited by john70t; 08-11-2011 at 12:23 PM.. |
Man cave costs........
I just had a 24'x28' + carport shop built (metal). Total cost including slab, building and insulation was $17.5k. I am now in the process of paneling the inside which will cost about $6-700 in materials. I have not gotten an estimate for the electrical yet. I am considering powering the shop with a portable generator to avoid monthly power charges. The generator would also be useful for the house in case of a power outage. I expect the total cost of the building will be between $20 and $21k.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
least common denominator
Be sure to set aside $25K for the home theater system
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Really good input from everyone, thanks. I want the construction to match my house and be low profile. I have a neighbor's view shed to be concerned about, so don't want to go crazy on the height. Besides, I like low-profile architecture that blends. I need a certain roof pitch for snow loads, and the deeper the building is, the higher the roof will be. I thought 22' would be fine. I'm going to acquire a ChampCar at some point to put in there, but it will be mostly bikes. 24' might be doable, too.
I'm waiting for one bid to come in, and I have a feeling its going to be around $80K. Everyone up here is super busy and nobody wants to work, so it aint easy to find a good contractor. Anyone want to come over next summer and work?
Now in 993 land ...
I am no architect or designer but IMHO you will want to have the same style gable roof with the same roof angle on your outbuilding as your main building. A simple pitch roof will look out of place and cheap next to the gable roof of the main house.
George |
AutoBahned
you might find out what needs to be done re basic structure (e.g. foam underneath the concrete slab) to have it be a dwelling unit and do that (document with pics in case you need to prove it later)
that way you can enhance your property value for eventual sale or stick kids in there, etc. the less you DIY, the more it costs - I only do carpentry, cabinetry & painting tho; I wouldn't touch concrete work with a 20 ft. bull float |
Well, I could'nt really give a rat's ass about resale value.... regarding permits, I remember when I was looking for land in this area. I asked my realtor about the permit process and how difficult/long it would take (being from SoCal). He looked at me like I was some kind of alien and said: "Its your gawdamm land, you do whatever you want with it". Yes, this is Montana
AutoBahned
are you in a town/city?
