rnln's Avatar
question on hanging an LCD.
What size of bolts/screws would you recommend me to bolt the bracket to the wall?
LCD TV is 50 inches and is heavy, an older type.
Wall is about 1", dry wall and plaster, before it come to 2x4.
I am thinking of 2.5" bolt (screw type) so I can have almost 1.5" of bolt in the wood beam (2x4). Any pro here? How about the diameter?
Thanks in advance.
Fat butt 911, 1987
Old 08-15-2011, 11:30 PM
Run smooth, run fast
Heel n Toe's Avatar
4" lag bolts oughta do it. Into the studs.
- John
Old 08-16-2011, 01:52 AM
1/4" to 3/8" bolts 3 1/2" long will do the trick. There are many not just two, so 1/4" bolts will do more then enough.
Old 08-16-2011, 02:04 AM
id10t's Avatar
The kit I used last weekend ot hang my 55" LCD came with 3" lug bolts
Old 08-16-2011, 05:51 AM
wdfifteen's Avatar
Four 3 1/2 x 1/4 inch lags in 3/16 pilot holes. Measure the shank and make sure you drill a 1/4 clearance hole the depth that the shank will extend into the wood.
Old 08-16-2011, 06:01 AM
rnln's Avatar
Let see if I got it.
Bolt: 3" to 4" length. 1/4" diameter bolt.
Drill hole: 3/16 diameter. Hole's length is as long as the bolt's shank.
Fat butt 911, 1987
Old 08-16-2011, 09:50 AM
Platinum Member
dad911's Avatar
I am a fan of Ledger-lock screws:
LedgerLok 3-5/8 in. Coarse Steel Hex-Head Ledger Board Fasteners 50 Pack-FMLL358-50 at The Home Depot
Started using them for decks and rails, but I use them for alot more.
Old 08-16-2011, 09:56 AM
Those things are the best. they are suppose to be stronger then 3/8" lag screws. I love them. Costly but worth the time saving.
Old 08-16-2011, 10:37 AM
