Trickle-charger question....
I have a couple of newish cars to store for 4 or 5 months. The place I want to store them has no electrical outlet, though I could run an extension cable in through a window.
Is there any fire risk in hooking up a trickle charger (unsupervised) for this length of time? Should I take out the batteries to reduce risk? Would just unplugging the leads (without trickle-charger) keep them alive for this length of time? Any thoughts?
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx |
I'm with Bill
A battery tender is designed to maintain a proper charge for extended periods of time, unlike a regular charger (even at a low rate) I would look into something like that for your needs. I have a 1/4 amp tender I use on my 911 when she goes to sleep for the winter and have had no issues.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Deltran Battery Tender, Brand Battery Chargers & Tenders, battery tender jr, battery tender plus
1996 FJ80. |
"O"man(are we in trouble)
I was in a guys hangar the other day and he has 4 battery tenders hooked up to snowmobiles. Leaves them on all the time. If his places goes, so does mine.
Canucks Fan
I worry about fire too and don't leave my tender on when I'm out of town, your probably safe but I worry about that kinda stuff so I just unhook the battery. Leave the tanks full of fuel and maybe a fuel conditioner might be an idea for that length of time.
Finn
From the Deep Dark Jungle |
Misunderstood User
I use a trickle charger from Nov 1 to March 1 with no problem. I use the 12v outlet inside the car.
The other option is to take the battery out and store it inside using the charger.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
I use a batery tender in the winter months. You want to use a smart charger not just a trickle charger. Mine never sits for more than two months max.
On many of the new cars the last thing you want to do is disconnect the battery. A new 997 will not even run if you disconnect and then reconnect the battery. You will be calling for a tow truck.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I leave Battery Tenders on my 930 and motorcycles all the time and have no concern about fire.
There's some cathodic protection for a vehicle with a negative ground so there's a reason to leave the battery in the car and connected.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Parrothead member
I leave a battery tender on my wave runner yr round. Never a thought not to.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Where would you expect a fire to start? At the battery? That's unlikely as there is no source of ignition.
The charging device itself might catch fire, but I think that is very unlikely. I use a cheap $10 charger (not a chipped trickle charger) on a 'outlet timer' all winter. One hour per day. I keep the charger on the cement floor (not under the hood). The reality is if you use a decent quality extension cord a decent charger (probably shouldn't use HF) then you should have no reason to lose sleep. On the other hand an acquaintance of mine lost his entire house due to a 'dollar store' power bar catching fire in the night.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 09-02-2011 at 07:03 AM.. |
Make Bruins Great Again
Most newer cars have a memory in their ECU so do not disconnect the battery without checking the proper reference manual for each vehicle.
Get a low low amperage float (or smart) charger. It will cycle on and off at certain battery levels. Some "trickle" chargers are just love amp chargers that send a small current of power all the time. As others have said, for peace of mind, avoid the HF unit. Lots of info here: Battery Tender - Home of the Battery Tender Jr. - Batterytender.com Setup the charger with the ring connections directly to the battery terminals (as opposed to the alligator clips) for a better connection. If you're wanting to be uber safe, you can connect the charger to a GFCI wall outlet.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Detached Member
If you take the batteries out, store them on a piece of wood. The cold concrete will hasten their discharge.
Hugh |
The V-I curbe of a trickle charger is shown below. I'm not real sure what is going to catch on fire. A GFCI will only protect you if you break the cover off the wall wart transformer and poke around in there.
Rick 88 Cab |
