Information Overloader
PTO Generator Question for PPOT Farmers/engineers
Say a 15 KW (16 Peak) PTO driven generator requires "at least a 30 HP tractor" to operate. Does this mean 30 HP at the PTO for the generator to operate at full load? I ask because I have a 23 HP tractor and am wondering if it will operate this generator if peak loads do not exceed say 10KW (my house with a well pump and electric water heater, lights. microwave)?
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Thanks, Red. The tractor manual says the PTO is estimated at 17.7 HP (13.2 KW). The gen. requires the standard 540 rpm which the tractor generates @ 3142 rpm.
So, at about 85% efficiency and a peak load of 10KW I'd still be well within the capacity of the tractor? I can't imagine the well, elec. heater, microwave and a few lights would exceed 10KW. Even then, were I to operate the house off the gen, I could temporarily disable the water heater just to be safe, correct? |
I spent a lot of time talking with the Winco folks and the MF dealer before I bought it. Both said it would work fine at less than peak loads. When I had the house wired for the generator to "plug" into the house, I made sure that the maximum circuit load was 2/3's the peak KW, which runs pretty much everything other than the HVAC. PM and I can go into the details. We average about 5 days without power every year so it has been a blessing.
1996 FJ80. |
Playing with the numbers for your PTO, scaling up for a 30hp and comparing that to the generator, I'm getting an efficiency of 87%, right in line with what I'm thinking. If the generator is 220VAC, you might consider a 50 amp breaker from the generator. This will be both a good safety device (disconnect) and limit the power to your house from the unit.
Unconstitutional Patriot
![]() Looks like bearded one has addressed your question, crowbob. I would like to add that you should not be afraid to run your tractor at PTO speed 24/7. The guys on tractorbynet say tractors can do this work day and night as long as it has clean fluid and air. I was considering adding an overdrive to the finish mower, so I could run lower rpms and still keep blade tip speed up. Guys were saying I won't save much fuel running at lower rpms. The fuel consumption is related to load and not rpm. |
What kind of tractor is this? A "23 hp tractor" should have 23 horsepower at the PTO, since that is where the power is measured from in the official OECD ratings tests.
Kubota. The manual says PTO is estimated at 17.7 HP (13.2 kW). 540 rpm at 3142 engine rpm.
