Evil Genius
Rusty Heap's Avatar
Serious - Drilling a square hole
VERY interesting cammed cutter chucked up in a CNC cutting chips in an aluminum test fixture.
Yup, drilling a square hole.
Slo Motion Video:
drill.mp4 video by randallwhitman - Photobucket
Life is a big ocean to swim in.
Wag more, bark less.
Old 09-30-2011, 02:59 PM
Dang, never would've believed it.
Thanks for posting this.
Scott
'78 SC mit Sportomatic - Sold
Old 09-30-2011, 03:50 PM
Reuleaux Triangle -- from Wolfram MathWorld
Old 09-30-2011, 03:52 PM
motion's Avatar
I watched the video and I still don't see how its possible... guess its not a true square. I had squares cut with a plasma burner a while ago into a piece of 3/16 diamond plate. Cool stuff.
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 09-30-2011, 04:49 PM
it looks like theres a dual action in the drilling process
Old 09-30-2011, 04:57 PM
Reg Reg is online now
Reg's Avatar
what about a mortise chisel? 4 sided chisel with drill bit in center - been around for ages.
1970 911 t (sold)
1985 MR2 (sold)
2011 GT 5.0
2007 CRV
Old 09-30-2011, 05:22 PM
MattKellett's Avatar
It using two processes to make the square hole. Basically rotating and chiseling, but the thing is moving so fast that we can't see the tool doing the chiseling.
I suspect it pauses rotation for a fraction of a second, while it chases out the corner with the chisel part of the cutting tool, similar to a hammer motion.
Edited - Basically as Reg says above, the wood working tool for this has been around for ages. Still a cool cnc process.
2 nd edit, if I'd bothered to watch the end of the video, I would have seen this!
Matt Kellett
87 Carrera Coupe - Marine Blue
60 MGA - Chariot Red
66 Jaguar MKII - Sherwood Green
09 VW GTI - Candy White
Old 09-30-2011, 05:26 PM
Vafri
I have a mortiser for woodworking, not new tech.
Old 09-30-2011, 05:27 PM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
If I remember correctly from a technical lecture (far too many years ago), it is theoretically possible to drill any multi-sided polygon shaped hole. The trick is to set up some kind of drive unit for the bit to perform a necessary similar type motion as shown in the video. The drill bit would always have one less cutting side than number of faces in the drilled hole, hence the 3 'sided' bit for a four sided hole. I would guess maybe it follows that one could not drill a 3 sided hole. At the end of the day, it probably has limited practical applications.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 09-30-2011, 05:32 PM
Non Compos Mentis
Old technology or not, somebody way smarter than me figgured that out!
Old 09-30-2011, 06:14 PM
Banned
Normy's Avatar
The specially-shaped bit moves in an eccentric motion. It is impossible to drill a square hole with just rotary motion. This whole thing requires a special drill, not just a special bit.
N!
Old 09-30-2011, 06:19 PM
Evil Genius
Rusty Heap's Avatar
blah blah blah, end of the day, it's cool to watch, UNDERSTAND, and hence I posted it...........
cough cough, so credit to the guy who give 2 edits to his post before even watching to the end of the 2 minute video.
geez they show the rotary cammed XY motion diagram in the first :20-:25 seconds.
things must be needed faster in CA. Microwave not always better, slow roasted meat gooderer
Old 09-30-2011, 07:03 PM
Max Sluiter
Flieger's Avatar
If the hole is big enough you can just use a normal milling machine bit on a square path. Then you even get nice radius edges as well. This looks better than broaching, though.
Old 09-30-2011, 08:27 PM
Haven't you ever done a crappy job of drilling through thin sheet metal and ended up with a hole roughly shaped like this with a regular old drill bit.
Old 09-30-2011, 09:19 PM
DUK DUK is offline
DUK's Avatar
I was just going to say, my drilled holes usually look triangular. So really I've already accomplished 3/4 of what they just did. LOL
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 10-01-2011, 05:38 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Very cool - I'm thinking of all kinds of uses for that...
Black Cars Matter
Old 10-01-2011, 05:48 AM
darnellsgarage
UK company Microbore makes tools that will do this and more....
don
Old 10-02-2011, 06:47 PM
