LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
AutoBahned
RWebb's Avatar
Plastering Question
Usually, plasterers put on a bonder (pink or blue) over the existing plaster before they put on more plaster (to fix a "bad hand" = ugly surface). I think this is called "thin wall" (??).
I had a guy do some repairs without using any bonder first - they are fairly small in area - about 1/2 ft. wide by 3 ft. tall, and another one about 1 ft x 1 ft. (these are on either side of a new window) - I had to chip some of it away to make my interior trim fit properly and noticed it really came off the wall easily.
---> Do I need to make sure he uses bonder before he puts on the plaster?
I am going to ask him to redo the entire area wall edge to wall edge to make sure he matches the hand (surface swirls), as he didn't match the existing hand before. This is that 1 ft. x 1 ft. area - it is pretty blobby looking.
He has to redo some of the plaster anyway - as he completely forgot to put any plaster above the window (!)
I want to make sure this gets done right... as it will be the 3rd attempt by this company... (but not by him - 2nd attempt by him).
Old 10-10-2011, 03:29 PM
JW Apostate
trekkor's Avatar
Yes, insist on a bonderizer. ( glue is their slang )
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 10-10-2011, 07:17 PM
Find someone that actually knows what they are doing. Your guy/company doesn't...
JR
Old 10-10-2011, 07:18 PM
AutoBahned
RWebb's Avatar
so, was bonder definitely required - even for the small strips (less than a foot across)?
re new company - that makes it a much bigger legal hassle, but we'll see
Old 10-11-2011, 12:32 PM
He needs to use a bonding agent.
Even on new construction it is code down here to use the bonding agent on the smooth concrete such as the lentils and tie beam before the scratch coat.
There are new bonding agents that are clear so they don't stain other areas. You should be able to get it at HD. Just apply with a roller.
Old 10-11-2011, 01:23 PM
AutoBahned
RWebb's Avatar
ok, this is over an old surface - which I think was plaster also
did it still need bonder?
Old 10-11-2011, 04:03 PM
Well, you can refer to all the posts that tell you to use it.
Or, you can consider that the repaired areas aren't sticking well.
I don't know, may be there's a conclusion that is escaping me....
JR
Old 10-11-2011, 04:20 PM
Zeke's Avatar
Old plaster that takes up water does not always need bonder and bonder was not always available. The area to be patched has to be firm and roughed up, scored is best. Old plaster sometimes needs to be treated. It can be too alkaline. Just spray some distilled vinegar on it.
Old 10-11-2011, 05:55 PM
AutoBahned
RWebb's Avatar
thx - I will make sure they use bonder over the large - wall edge to wall edge area - about 5 ft. high by 10 feet across.
Old 10-11-2011, 06:00 PM
