My flat screen is dying
It just turned yellowish after flipping from bright to yellowish for several days.
I'm gonna shut it off for awhile and see what that does. It's not really matched to the card in my tower. Is that what's killing (killed) it? |
See if adjusting the cable changes the colors.
The FL inverter could be going or caps are dying.
Used Up User
As above, adjust the cable. Unplug & replug. But computer monitors appear to have a slim 2 - 5 year life span from what I have gone through.
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
I just wiggled the cable. Back to bright. Who'd a thunk?
Much obliged. |
Yup, cable loose or cable going bad will do that...
19 years and 17k posts...
Is it a Sony Bravia?
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
HP f2105. This sucker is bright now. I'm going to adjust the brightness.
Well Milt, it is time to get a better setup. Try a 34 to 36 inch HD TV with PC HDMI input such as the Sony I bought last month and put in a video card that with a HDMI output and you will be knocked over! My 34 inch monitor was less than $300 at Walmart, the video card with 1GB of memory was $49 and my eyes do not get tired any longer! If wondering what to do, check out MPEG . ORG - MPEG Home for ideas.
Well, I found out that it wasn't the cable. I'm using the old cable on my new monitor. This new monitor is a POS, especially the speakers. Since the problem could be temporarily fixed by moving the cable connection at the monitor, do you think I can get a new multi pin plug and install it?
The old monitor has memory card slots, side mounted USBs, and a firewire connection that I never did know what that did. Oh, I guess that was for the USBs and card slots. Never used them. Seemed like a pretty good set up but it is an HP that is 6 years old at this point. Or maybe someone has some speakers they could sell me for not too much.
You probably use old-style analog RGB-cable which has lot's of pins and is prone to problems. If monitor has DVI, use it instead.
Thank you for your time, |
Senior Member
Just had two repaired over here. Both were bad caps...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
As I said, I could wiggle the cable and the colors would return to normal. It does have DVI input, but my tower does not have that output that I know of. That would probably work changing the input.
Edit: I just found out it IS the cable! Putting new cable in now. Last edited by Zeke; 08-28-2012 at 10:18 AM.. |
