How to wrap a cat for Christmas
How to wrap a cat for Christmas | VidAddict.com
Looks pretty simple.
Old 12-19-2011, 12:38 PM
74 911Ebay
this is not going to end well.
The world needs more Protest Singers
Old 12-19-2011, 12:42 PM
B58/732
BlueSkyJaunte's Avatar
Giftwrap cat just don't give a ****.
ΜΟΛΩΝ ΛΑΒΕ
Old 12-19-2011, 12:48 PM
ZOO ZOO is online now
One of my facourite cartoons was a guy with a cat at FedEx, and he wanted to know how far he could send the cat for $20.
Old 12-19-2011, 12:49 PM
I guess you just don't know how to do it properly. Watch the informative video, it looks quite easy.
Old 12-19-2011, 01:04 PM
redstrosekNic's Avatar
I want to see them wrap a honeybadger...
:P
Dustin
Old 12-19-2011, 01:11 PM
Old 12-19-2011, 02:31 PM
I'm with Bill
Rick V's Avatar
I would like to see someone try that with one of my psycho cats. I could make the follow up video of how wrap multiple lacerations....
Old 12-19-2011, 03:07 PM
Zeke's Avatar
That poor old timer could hardly walk to the paper. Old cats have a lot of patience with stupid people.
Old 12-19-2011, 04:25 PM
Senior Member
Originally Posted by NotaBRG View Post
That's not how I wrapped mine before I sent it out.
Had to thump mine on the head but after that it was very docile going in the box. Just hope it did not wake up in the post office...
Old 12-19-2011, 04:37 PM
JW Apostate
trekkor's Avatar
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 12-19-2011, 05:00 PM
Make Bruins Great Again
Por_sha911's Avatar
It usually goes more like this.
Wrapping Presents With A Cat
1. Clear large space on table for wrapping present.
2. Go to wardrobe and collect bag in which present is contained, and close door.
3. Open door and remove cat from wardrobe.
4. Go to cupboard and retrieve rolls of wrapping paper.
5. Go back and remove cat from cupboard.
6. Go to drawer and collect transparent sticky tape, ribbons, scissors, labels, etc.
7. Lay out present and wrapping materials on table, to enable wrapping strategy to be formed.
8. Go back to drawer to get string, remove cat that has been in the drawer since last visit, and collect string.
9. Remove present from bag.
10. Remove cat from bag.
11. Open box to check present, remove cat from box, replace present.
12. Lay out paper to enable cutting to size.
13. Cut the paper to size, trying to keep the cutting line straight.
14. Throw away first sheet because cat tried to chase the scissors and tore paper.
15. Cut second sheet of paper to size by putting cat in the bag the present came out of.
16. Place present on cut-to-size paper.
17. Lift up edges of paper to seal in present, wonder why edges now don't reach, and find cat between present and paper. Remove cat and retry.
18. Place object on paper, to hold in place, while cutting transparent sticky tape.
19. Spend next 20 minutes carefully trying to remove transparent sticky tape from cat with pair of nail scissors.
20. Seal paper down with transparent sticky tape, making corners as neat as possible.
21. Look for roll of ribbon; chase cat down hall and retrieve ribbon.
22. Try to wrap present with ribbon in a two-directional turn.
23. Re-roll up ribbon and remove paper that is now torn, due to cat's enthusiasm in chasing ribbon end.
24. Repeat steps 12-22 until down to last sheet of paper.
25. Decide to skip steps 12-16 in order to save time and reduce risk of losing last sheet of paper. Retrieve old cardboard box that you know is right size for sheet of paper.
26. Put present in box, and tie down with string.
27. Remove string, open box and remove cat.
28. Put all packing materials in bag with present and head for lockable room.
29. Once inside room, lock door and start to re-lay out packing materials.
30. Remove cat from box, unlock door, put cat outside door, close door and re-lock.
31. Lay out last sheet of paper. (Admittedly this is difficult in the small area of the toilet, but try your best!)
32. Seal box, wrap with paper and start repairs by very carefully sealing down tears with transparent sticky tape. Now tie up with ribbon and decorate with bows to hide worst affected areas.
33. Label, then sit back and admire your handiwork, congratulating yourself on making good of a bad job.
34. Unlock door, and go to kitchen to make cup of coffee and feed cat.
35. Spend next 15 minutes looking for cat, before coming to obvious conclusion.
36. Unwrap present, untie box and remove cat.
37. Retrieve all discarded sheets of wrapping paper, feed cat and retire to lockable room for last attempt, making certain you are alone and the door is locked.
38. At time of handing over present, smile sweetly at receiver's face, as they try and hide their contempt at being handed such a badly wrapped present.
39. Vow to yourself that next year, you will get the store to wrap the thing for you.
Joe
Old 12-19-2011, 05:06 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
i have never seen a cat who would sit still long enough to endure that!
Old 12-19-2011, 05:18 PM
pwd72s's Avatar
Try that with one of ours & you'd have to rename yorself...Claude Balls.
Old 12-19-2011, 05:57 PM
Rob Channell's Avatar
A Christmas present for Schrodinger?
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 12-19-2011, 07:40 PM
Paul, that cat looks like it would tolerate no scheisse from anyone, or anything!
Dave
1969 911T Coupe
1972 911E Targa
Old 12-19-2011, 07:45 PM
pwd72s's Avatar
Actually, he's a 20 pound lover...but ohboy does he have a strong will. Takes no krap from his 16 pound "little" brother. Siblings we picked up at the local no kill shelter. Would have been criminal to separate them.
Old 12-19-2011, 07:52 PM
That is a really cool pair. We have a hard time putting the set of "cat antlers" on ours at Christmas....and they never stay on long enough for a picture.
Dave
1969 911T Coupe
1972 911E Targa
Old 12-19-2011, 07:56 PM
pwd72s's Avatar
Cat antlers? HOOT! I don't think I'd even try...
Old 12-19-2011, 07:59 PM
I think it will hard for me coz', cat is very restless.
Old 12-19-2011, 10:01 PM
