cantdrv55's Avatar
Heat or ice for my lower back?
Experienced pain on my lower back while brushing my teeth this morning. It brought me to my knees, crawling on my hands and feet back to bed. On call nurse said take ibuprofen and rest it but didn't mention icing or heat. Shouldn't I do one or the other though?
Old 01-31-2012, 11:31 AM
vash's Avatar
man. how hard do you brush?
hope you feel better.
poof! gone
Old 01-31-2012, 11:50 AM
cantdrv55's Avatar
That's the same question wifey asked. Just woke up stiff and bent down kinda funny is all. Must be getting old. Staying home from work today.
Old 01-31-2012, 11:52 AM
AutoBahned
RWebb's Avatar
no heat for a day or two
Old 01-31-2012, 12:01 PM
Seldom Seen Member
Burnin' oil's Avatar
Time.
What is the "ticker" and how come it's static??
Why do things that happen to white trash always happen to me?
Got nachos?
Old 01-31-2012, 12:04 PM
Former Drama Queen...
12own911's Avatar
Send a message via Yahoo to 12own911
My chiro says to apply ice... 15 minutes on / 15 minutes off for a few hours. My inner chiro says to apply heat...
My inner chiro always wins over the real doctor.
Bad, I know.
~ Kim (KDOLL2)
It is better to cry in a Porsche then in my Vue...
Old 01-31-2012, 12:07 PM
Seldom Seen Member
My inner chiro says wine, and lots of it. He thinks that's the cure for everything, and he always wins.
Got nachos?
Old 01-31-2012, 12:10 PM
madmmac's Avatar
Ice now, heat later.
Ice reduces inflammation, heat promotes blood flow for healing.
Did you hear of feel a click or clunk when it happened?
Good luck.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 01-31-2012, 12:14 PM
Regenerated User
72doug2,2S's Avatar
So now we're calling it brushing our teeth, are we? What position was your wife in when this happened?
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 01-31-2012, 12:16 PM
cantdrv55's Avatar
I like the wine idea. I always listen to my inner chiro as well. I heard or felt a pop. Could just be my bones cracking?
The ticker is stuck because I don't know how to update it and forgot the password for the account. I'll remove from my sig. Not much change anyway - bouncing around 210 - 215.
Old 01-31-2012, 12:19 PM
cantdrv55's Avatar
Someone was gonna ask sooner or later. I wish that was the cause
Old 01-31-2012, 12:20 PM
nostatic's Avatar
ice good, heat feels good but is bad
Old 01-31-2012, 12:23 PM
Used Up User
imcarthur's Avatar
Good luck. My last lower back issue went on for 6 weeks. I would add muscle relaxants & wash them down with the wine already prescribed.
Ian
'87 Carrera Cab
Old 01-31-2012, 12:28 PM
madmmac's Avatar
Hopefully just a disc slippage.
Once you get more comfortable, laying on your back, using your arms bring 1 leg up in a bent position and slowly pull towards your chest. The other leg is laying straight. Alternate legs. At any time if you feel increased pain, STOP.
Look at my x-ray. That should cheer you up.
madmmac AKA Mitch
2006 4Runner
Old 01-31-2012, 12:30 PM
dennis in se pa's Avatar
Ice. I often have lower back issues. My chiro says ICE.
And the only thing I have found to truly take away pain is........
VODKA!
The drugs they gave me after a serious hernia operation did not work. VODKA did. Thank GOD for VODKA!
Old 01-31-2012, 01:05 PM
Mix the Vodka with some Vicadin and you are on your way to recovery!
I have found that some decent rest for a couple of days followed by some mild stretching to take pressure off the spine seems to work.
Swimming in a cold pool helps me as well.
Randy
'87 911 Targa
'17 Macan GTS
Old 01-31-2012, 01:21 PM
cantdrv55's Avatar
Thanks gal and guys. So wine, vodka, Vicodin, stretching, ice and swim in a cold pool. I'll be a drunken, drugged up fool with shriveled you-know-whats in no time.
Old 01-31-2012, 01:39 PM
12own911's Avatar
Then add heat after the swim to get the blood flowing again.
~ Kim (KDOLL2)
Old 01-31-2012, 01:41 PM
vash's Avatar
.........shriveled you-know-whats in no time.
good. the less weight cantilevered out front, the better.
poof! gone
Old 01-31-2012, 02:10 PM
nostatic's Avatar
Only if you have a newer formulation with lower acetominophen amounts. While opiate/alcohol is a dangerous mix, alcohol/acetominophen is as bad or worse.
The above has no warranty implied or expressed. I am not an MD nor did I sleep at a Holiday Inn Express last night.
Old 01-31-2012, 02:15 PM
