maybe. A long time ago, I was dumb enough to buy Campy grease. It works ok, what did I know? It was used in everything from repacking hubs and BBs, to greasing seat posts. I can't or refuse to understand back then why a 99 cent tub of Shell grease at K mark was not good enough for my bike? The dumb Campy grease was something like 15 bucks. Park grease is good stuff. Now, how do I get some of that stuff in my shifter will keep up all night?
You obviously need to go electric. Probably not much greasing in a Di2 shifter.
Midway USA has it their latest flyer for $7.49 + shipping.
BernieP |
Unregistered
I buy about 20 gallons of kroil a year for my shops and field machinists/millwrights, IMO it's the best stuff out there.
I've seen the atf/acetone report but color me skeptical. There's much more to determining what works and what doesn't than the simple test they performed. In real world application kroil works really, really well. BTW it's available in aerosol or liquid form, buying it in non-aerosol is way cheaper and better for the environment and worker safety. Just put it in a $1 spray bottle. More on the parts, less in the air to breathe. |
Unregistered
Whenever I sold a set of campy hubs or bottom bracket or was servicing them, the first thing I'd do was wash out all the campy grease and replace it with waterproof Phil wood grease. And only a little, not too much. I loved that stuff and it wasn't expensive. I also used to pack the higher end japanese hubs (shimano etc) with crest toothpaste and ride them for a half mile or so and then rebuild them with new ball bearings, It polished the races without damaging them, making them so much smoother and more precise than the campy stuff ever was. Racers paid big $$$ for that kind of stuff. I also got $6 each to patch sew-ups as a side job. Righteous bucks back then. I got to where I could almost do it unconsciously while watching TV. |
I've used the ATF/acetone mix and it does work well. I've never used Kroil - so I don't have a direct comparison. The only problem with the ATF/acetone mix is how to store and dispense it. I've got a small old-style pump oil dispenser, but this mixture is so low in viscosity, it leaks all over and is difficult to control placement.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
AutoBahned
the other, and more serious, problem is to avoid exposure to the acetone -- it is not exactly good for you...
AutoBahned
Targa, Panamera Turbo
Tell that to the 180,000,000 women in the US that use it to take of fingernail polish! Agree, the stuff is harsh on your liver.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
AutoBahned
I have indeed explained the problem to a few of them...
Maybe you can help, since the number is so large. Let's split it in half. I will take the hottest 90,000 minus the crazy redheads, and you can take the rest of them. |
I'll take the redheads between 28 and 43, size 6 or less...
least common denominator
Yeah but mixed with cranberry juice it is a mean buzz!
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
The 50/50 atf/acetone is really interesting.
Dan |
Sentry Solutions: Precision Applicator Needle Oiler Bottles If you go to a hobby shop you will find a metal needle dispenser normally used for very thin plastic cements. see what they have.
Dan |
Good to know. Where are you in CA? You never know when something like that will come up and you have to have it immediately. something about buying an item over the counter the old fashion way.
Here's a list of penetrating oils from McMaster-Carr. Usually 1-2 day turnaround in LA.
McMaster-Carr However, you may have to buy a case qty. S |
Just thinking out loud
S'OK! is the best stuff out there. It's never been compared to the popular penetrating oils in a testing environment/competition because it's in a league of its own. Kroil won't accept an open invitation for comparison. I have to recon they know they'd lose.
Shamrock Specialties - S'OK! and TAT'L
83 944 91 FJ80 84 Ram Charger (now gone) |
Sammy, I used to do the same thing, but start off with Semichrome, and then toothpaste. I have a set of Zeus hubs on the Cannondale that's smooth as silk. We also used to mix Mobil1 30W, and parafin in a pot with low heat, and then soak our cleaned chains in it, wipe it down, and reinstal them. We need to start a thread on this kinda stuff.
Brent Early85 944 LM6Y Paint Code |
I live in Ventura County. You have a PM. DanB
Dan |
