Slackerous Maximus
HardDrive's Avatar
Converting a 900cc Ducati engine to a single, how hard?
If I bought a carbed 900cc Ducati engine, how hard would it be to convert it to a single? I'm guess not that hard, since I drove my 900SS with a fouled plug on one cylinder, and it ran.....with admittedly less power.....
Could it be as simple as removing the piston, sealing off the case, and removing the wiring for the missing cylinder?
2014 Cayman S, PDK
Old 02-11-2012, 10:17 PM
slodave's Avatar
No answer whatsoever. But, why (short of the obvious less power)?
Old 02-11-2012, 10:23 PM
TheMentat's Avatar
It would probably run smother if it were properly balanced to run on one cylinder...
Old 02-11-2012, 10:55 PM
maxnine11's Avatar
Ducati already did that (sort of) quite some time ago.
The Supermono is a gorgeous bike.
I have an old 450 single ... i wouldn't describe it as 'smooth'.
Although a rebuild is probably due.
max
Old 02-11-2012, 11:16 PM
rfuerst911sc's Avatar
That is a nice looking machine.
Old 02-12-2012, 05:41 AM
FUSHIGI
was more than one ever made? I hope not as the possibility of owning one would haunt me.
Old 02-12-2012, 06:26 AM
Slackerous Maximus
HardDrive's Avatar
So it could sit in a Royal Enfield Bullet frame.
2014 Cayman S, PDK
Old 02-12-2012, 06:46 AM
Friend of Warren
I would think it would vibrate terribly. The crank is balanced for two pistons.
Kurt V
Old 02-12-2012, 06:59 AM
Kantry Member
oldE's Avatar
At best, you'd need a new crank.
Les
Best
Les
Old 02-12-2012, 09:44 AM
motion's Avatar
I have a buddy that made a single out of a new Ducati 1098. Remove hardware, fab block off plate, re-balance crank (the tricky part). It can certainly be done.
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 02-12-2012, 02:12 PM
5String
Good God, why would you?
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 02-12-2012, 04:25 PM
FUSHIGI
oh man...wikipedia has total supermono production run of 65...
Old 02-12-2012, 05:00 PM
Slackerous Maximus
HardDrive's Avatar
Because I'm an idiot with a checkbook.
2014 Cayman S, PDK
Old 02-12-2012, 05:09 PM
beancounter
jwasbury's Avatar
One of the sexiest, most coveted Ducatis of all time.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-12-2012, 06:12 PM
80 930, 74S
Nothing greater.
Old 02-12-2012, 06:26 PM
---Vincent H.R.D did it many years ago, I worked with a guy had a Vincent 'Comet"---500cc
single. The rear barrel was removed and a blanking plate on the case. I dont know what they did inside. I travelled pillion on it daily for some months, [1959/60]----
Well I guess my memory is fading---I recalled 'Google is your friend' and came up with this----------
How the legendary Vincent Rapide V-Twin engine was concieved is certainly one of the most tantalizing legends in all of Classic British Motorcycle-dom. Phil Irving was sitting at the drawing board one day with two tracings of the 500cc single. As things got moved around, the top tracing roughly lined up with the bottom one (identical to the top) at such an angle as to look like a V-twin. With a little cajoling, he lined up the crankshaft centerlines & the timing idler gears & ended up with a 47.5 degree V-twin. The single you see, was canted forward at 23.75 degrees, so this just duplicated that angle to the rear. In doing so, the 1936 Series A Vincent Rapide was born. The 994cc V-twin had 6.8:1 compression, made 45 hp & was good for 110 mph. Absolutely stellar performance in 1936! The Series A (or first generation) engine was somewhat crude when compared with later models, with its non-unit construction & exterior oil lines. The clutch & transmission was also weak. But the Vincent Rapide was still a stunning success for the tiny Vincent-HRD Motorcycle Co. It had a brazed lug frame with Vincent’s patented cantilever rear suspension & a girder front end.
Old 02-12-2012, 07:48 PM
Now accepting US $ at par
dienstuhr's Avatar
Here's a story about a fellow who did just that with his 748.
Ductalk
Again, what could possibly be so great about an Enfield Bullet frame that would make a grown-up person want to do that?
d.
1985 911 Carrera Coupe
2015 Volkswagen GTI 6-spd
some motorcycles
Old 02-13-2012, 11:22 AM
Champagne on Beer Budget
HelmetHead's Avatar
This guy did it with a HD motor...and built a beauty of a ride doing it!
Nortorious by Roger Goldammer
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 02-13-2012, 12:50 PM
motion's Avatar
SuperMono, yummmm. Last I heard they were going for around $75K a pop. I saw a guy at California Speedway tracking one once. Respekt!
Old 02-13-2012, 01:05 PM
beancounter
jwasbury's Avatar
I ran my Duc M900 in AMA club racing for a couple seasons at NHIS (Loudon, NH). The local race school (Penguin) owner, Jerry Wood, was racing his Supermono every weekend. The dude was seriously fast, and was usually winning the Formula 40 race (over 40 years old required, otherwise open class).
Jacob
Old 02-13-2012, 01:33 PM
