Zink Racer
2006 mini thermostat
I know I should post this on the mini forum or another forum but I'm lazy and I know there are several mini owners who hang out here. There's like one lonely guy on the BMW/Mini Pelican forum waiting for others to come play.....
My GF has a 2006 base mini. Leaking coolant a year + ago fixed with thermostat and gasket. Now leaking again and the repair is no longer under warranty
Google search says thermostat and gasket on 05/06 minis is a known issue.
Is it worth calling the dealer? Has the part been redesigned maybe? Are they a pain to change. Anyone else had this issue?
Jerry
Old 02-18-2012, 03:02 PM
beancounter
jwasbury's Avatar
The thermostat housing has been changed once by the dealer on our '06 Cooper S. It was out of warranty already when it happened. I think it must be pretty accessible because I don't recall that it was terribly expensive.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-18-2012, 03:22 PM
Friend of Warren
Not that hard to do. I would suggest changing the housing while you are at it.
Kurt V
Old 02-18-2012, 04:52 PM
GothingNC's Avatar
Here is the water pump replacement.
Pelican Technical Article: Water Pump Replacement - - R53 MINI Cooper S (2002-06)
T-Stat-a lot easier
http://www.northamericanmotoring.com/forums/how-to/191757-maintenance-thermostat-change.html
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 02-18-2012, 07:07 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
It's not that difficult to change the thermostat. Read my article above.
The biggest thing is getting access. Taking the front bumper off makes it a bit easier.
Change the housing at the same time and also inspect the water pump. On a base model, there's less stuff to remove.
Old 02-18-2012, 07:18 PM
David McLaughlin's Avatar
Fow what it's worth, the waterpump just went on my '10 justacooper. It may be worth looking at that too.
1970 914/6 RustoMod
2015 Mercedes E400
Old 02-19-2012, 10:11 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Look into it. Recall for the controller for the waterpump is in process. Taking my '11 in on Wed. for the work.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 02-20-2012, 09:05 AM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
i didn't do any research before changing the t-stat and housing on our '06 GP, but was able to do it without removing the bumper. A bit of a PITA, but not really that bad. Most of the issue was having hands that were too big going into an engine compartment with hardly any room. Yes, change housing/gasket/t-stat at the same time.
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 02-21-2012, 04:28 PM
