How to Open a Safe...........
Well, I picked one up that I want to open, came out of a Bar I use to spend a lot of time & $$$ in (Vinny knows the one) and it is going in my Man-Cave, but would like to open it up and restore 1st..
Old 04-11-2012, 02:44 PM
At a prior job I had one similar in size and age opened by a pro. He drilled it on the side - maybe a 3/8ths hold - and was able to get it open that way. Then we just welded up the hole - though it really wasn't necessary.
1972 911T/S MFI Survivor
Old 04-11-2012, 02:51 PM
Banned
U mean u don't have the combo?
Old 04-11-2012, 03:03 PM
19 years and 17k posts...
azasadny's Avatar
I took a similar locked safe to a local locksmith (who has since retired) and he charged me a very reasonable amount to open the safe...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 04-11-2012, 03:16 PM
I guess a 40# shape charge is not an option.... I'd make some calls to old-school locksmiths..
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 04-11-2012, 03:19 PM
Come to think of it, the guy we used claimed he almost opened it with a listening device.
pete3799's Avatar
Pete
79 911SC RoW
Old 04-11-2012, 04:00 PM
Jim Bremner's Avatar
Please use PM's don't post this in an open forum
Old 04-11-2012, 04:11 PM
GWN7's Avatar
Neibour was a locksmith. He used to drill them and then use bodyfiller to patch the holes.
Bunch of old cars
Old 04-11-2012, 04:15 PM
Zeke's Avatar
I think if you have the time, Byron, that you could Google the technique and give it a go. I'd try for at least a day.
Old 04-11-2012, 04:17 PM
Detached Member
Hugh R's Avatar
Looks like the Diebold in my garage based on the dial and age. PM me your email and I'll take a picture of the "tumblers" inside, that might help.
Hugh
Old 04-11-2012, 04:28 PM
Zeke's Avatar
Let's start a lottery on the numbers.
Closest to the actual numbers gets a Byron gift.
10-33-27 and 4 if it's a 4 no. combo.
Old 04-11-2012, 04:34 PM
couple of ways best is if it can be picked. 2nd drilled by a locksmith who knows where to drill and install a scope. After he'll jb weld a steel bb in the hole. 3rd is to cut a large hole in the back remove the lock from the rear of the door and weld up the hole once done. If you don't care about the safe I could get in many other ways.
Old 04-11-2012, 04:41 PM
Old 04-11-2012, 05:22 PM
Double Trouble
targa911S's Avatar
11- 47-14-(35)
Old 04-11-2012, 07:49 PM
Thanks Hugh, and the rest of you guys, I plan on working on it myself 1st.
Old 04-11-2012, 07:51 PM
MBAtarga's Avatar
okay - since no one else has yet, I'll suggest this as the combination:
8 - 6 - 7 - 5 - 3 - 0 - 9
Mark
'83 SC Targa - since 5/5/2001
Old 04-11-2012, 08:23 PM
It should be a 4 combo dial if I 'member right it's to the left first than to the right 3 turns than to left 2 turns right one turn and back to the last # The dial pack slips on to a splined sprue. you can modify all #'s but the last one. If you own a borescope I can tell you where my door has been drilled.
Old 04-11-2012, 08:40 PM
A930Rocket's Avatar
36-24-36
Old 04-11-2012, 09:01 PM
Only if she's 5'3"
1987 944S
Old 04-11-2012, 09:55 PM
