least common denominator
scottmandue's Avatar
Balancing tires after rotating? Nessary?
I had a slow leak in one tire and it was time to rotate so I went down to America's tire where I get all that done for free because I buy my tires there.
The guy at the counter says "we have a special, do you want us to rebalanced the tires for $20?"
Uh, no...
Am I wrong? Should I got them balanced? I have been around for a while and don't remember ever having to balance tires more than once.
I think we have some guys here that have worked in tire shops and perhaps you can enlighten me.
Thanks in advance
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 04-18-2012, 10:30 AM
Driver
Noah930's Avatar
Isn't lifetime rotation and balancing part of the deal when you buy (and have them mount) tires?
But tires can become "unbalanced" with use. Though I don't think I've ever had a tire rebalanced along the way (short of after having had them patch a nail).
1990 Black 964 C2 Targa
Old 04-18-2012, 10:33 AM
pete3799's Avatar
To properly fix a leaking tire it must be removed (patched on the inside) so at a minimum that tire needs to be rebalanced.
Are your tires directional? If so to rotate them they would need to be dismounted and would then need to be balanced.
Pete
79 911SC RoW
Old 04-18-2012, 10:39 AM
If there is no symptom of being unbalanced, then there is no need to rebalance them. If there is a vibration, then they need to be balanced.
If you're not good at self-diagnosing or "feeling" your tires, you're likely much better served popping for a $20 rebalance than running the risk of damaging tires, suspension components, and wheel bearings driving with an unbalanced tire.
I love you guys outside this forum
-Eric
Old 04-18-2012, 10:40 AM
I am pretty good at "feeling" my car...
Wonder why the guy didn't mention that we should have at least balanced the leak repair tire... hmmmm...
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 04-18-2012, 10:59 AM
If they are balanced, leave them be. Maybe from driving DE's, but I have a complete aversion to vibrations at high speeds. My Acura dealership is actually one of the worse places to get my tires balanced and I quit taking them there. I have a friend that works at Nissan and he does a great job. It's all in the care someone takes thats doing this.
Old 04-18-2012, 11:05 AM
pete3799's Avatar
Like i said....a good tire repair is done from the inside (tire dismounted)
A lot of shops just ram a plug in it from the outside. The problem with this is the plug they put in will absorb moisture into the tire and moisture will rust the steel belts.
They (tire plugs) are fine in a pinch if your on the side of the road with a flat but should be considered a temporary fix.
Pete
79 911SC RoW
Old 04-18-2012, 12:31 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
free rotation and ballancing of tires for the duration of warranty at discount.
if the repair the tire they should check the balance.
weights can come off the rim at any time so they may still need to be ballanced
check your recipt of purchase of the tires. they may be upselling you something you should already get for free.
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 04-19-2012, 04:29 PM
Originally Posted by teenerted1 View Post
free rotation and balancing of tires for the duration of warranty at discount.
weights can come off the rim at any time so they may still need to be balanced
check your receipt of purchase of the tires. they may be upselling you something you should already get for free.
This car only has 25K miles... I put some cheap alloy wheels on it that I bought and had mounted at this shop... also have bought three or four sets of tires at this shop for previous cars, but these tires are still OEM. Rotating and flat fix are free... balance is a gray area.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 04-19-2012, 04:50 PM
Driver
Noah930's Avatar
Ah, OEM tires. Didn't catch that part.
I use my local America's Tire, as well. The one time I had an OEM tire plugged, I can't recall if they balanced it afterwards. But it didn't vibrate, so I never thought about it (until now).
Still, I thought that if you pay for mounting (even if you didn't buy the tires there), it's free lifetime tire repair, rotation, and balancing. IIRC.
Old 04-19-2012, 05:22 PM
AutoBahned
RWebb's Avatar
if the car runs smooth at 165 mph just figure it's good enuff for most stuff
Old 04-19-2012, 05:24 PM
rnln's Avatar
kaisen is right on. If you don't have vibration nor boucing problem, save $20. But if they repair leak on that one tire (took it off the wheel and remount), they should balance that tire even if you decided not to pay for balancing all 4 tires.
Fat butt 911, 1987
Old 04-19-2012, 08:02 PM
rnln's Avatar
mine is good at 164. Have not tried 165 yet.
Fat butt 911, 1987
Old 04-19-2012, 08:05 PM
