Cars & Coffee Killer
How to remove a battery?
So a battery apparently ruptured in my 4-cell Maglight. I had to put it in a vice to get it open, and the bottom D-cell is swollen and corroded to the flashlight body. Any tips/tricks for pulling the battery and cleaning the aluminum flashlight body?
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Last time I had a Maglite do that, I removed all the parts I could for future use and ditched the rest.
That's all I got. |
Had the same thing happen to me. Called mag lite and they told me to send it in. A few days later had a brand new flashlight. That was some time ago but I would at least try.
Pete
1983 SC 1958 TR3 2014 Cayenne GTS (wife' car) 2006 KTM 450EXC |
Run smooth, run fast
Maybe soak the bottom cap and bottom four inches of the shaft in a water-baking soda mix and see if that cuts/dissolves the corrosion out of there.
- John "We had a band powerful enough to turn goat piss into gasoline." |
Almost Banned Once
Use some alcohol to dissolve the residue. (wood alcohol or isopropyl) Then they should just fall out.
My BILs noise cancelling headphones had a leaky battery that was stuck in place. I just soaked the battery socket with alcohol and then used a small pick to get it out.
- Peter |
Canucks Fan
We have had the same problem and most times it was a lost cause, probably have had 7-8 of them destroyed but for us at work it was from bad battery's. Its the third world where I work and getting good Duracell or Energizer battery's is tough, the company's sell their reject batteries to recyclers and they package them up and sell them as good, it will show a Duracell battery in the pack but won't have the brand name on the pack and it was these rejects that caused the problems, it got so bad that we switched to the LEd lights that wou wear on your head, AAA batteries and I just bring them from home. What brand of battery were you using?
Finn
From the Deep Dark Jungle |
Detached Member
Take a large lag bolt and ram it in and pull it out. Maglight typically doesn't replace for a bad battery.
Hugh |
Bill is Dead.
This worked for me recently with a 2D maglight.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
