dennis in se pa's Avatar
Rigid 3300 Pressure Washer - WOW!!!!
Should be spelled RIDGID, sorry.
Yes, there are discussions here, but I want everyone to know about this. Some others may be in the market for a pressure washer and want something serious, not an electric toy. The RIDGID 3300 has a Subaru OHC motor and a CAT pump, which my research tells me are top of the line. Got it at Home Depot. Went together easily, started right up. Unbelievable power. I really like the "throttle down" feature. I think you could cut holes in wood with this thing.
Old 05-27-2012, 08:30 AM
Team California
speeder's Avatar
Comes down to the right tool for the job. That would do nothing but expensive damage to the things I point a pressure washer at. I'm about to buy an expensive ~1000 psi. PW.
If you're cleaning barnacles off battle ships, that sounds like a perfect tool.
Denis
Old 05-27-2012, 11:18 AM
But its got no heat!!! Our pressure washer has an electric pump, and a big azzed diesel burner!
It will take paint off if you aren't careful....
Old 05-27-2012, 11:22 AM
biosurfer1's Avatar
when I worked at a new VW dealership, the manager asked us detailers what we needed and we said a pressure washer would be nice. The manager was a bit of a "if big is good, bigger is better" type of guy and got us a 4000psi pressure washer with hot water tank. One of the tips was 10 degrees and it would easily etch concrete without any trouble. We threw that away quickly before one of the dumbass sales guys used it on a car by accident.
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 05-28-2012, 10:09 AM
"before one of the dumbass sales guys used it on a car by accident."
Yeah, but......
If those dumbass sales guys don't sell cars NO ONE there has a job anymore.
There are different jobs to be done, and different brains to do them.
Old 05-28-2012, 11:43 AM
rfuerst911sc's Avatar
Watched a guy at Home Depot a few years ago cutting hardwood pallets with a pressure washer. It's easier to dial back a good pressure washer vs. not having enough power.
Old 05-28-2012, 12:54 PM
Yeah, but......
True dat but still doesn't NOT make them dumbazzes....just necessary dumbazzes...
Old 05-28-2012, 01:38 PM
Fleabit peanut monkey
Bob Kontak's Avatar
The RIDGID 3300 has a Subaru OHC motor and a CAT pump,................ I really like the "throttle down" feature.
I own one. Have had if for over a year. They are made with fuel injection or carb. Get the carb. Then you get the idle down feature. I first bought the fuel injection. Did not like it and returned.
I like it a lot. Well worth the extra few hundred dollars over the smaller units.
Old 05-29-2012, 01:02 AM
Almost Banned Once
sc_rufctr's Avatar
(ex Army medic) 20 years ago I had to do first aid on a mechanic who had cut his foot with a petrol powered pressure washer.
He was cleaning he underside of a truck and had flip flops on.
.... Horrible. I looked like an axe wound and it took weeks to heal
Off topic but even worse was a Namibian guy who had been tortured with an industrial sand blaster. When I got to him most of his muscles were striped off his feet and legs.
He spent months in a UN hospital and lost both of his legs from the knees down.
- Peter
Old 05-29-2012, 02:35 AM
Bob Kontak's Avatar
However, the RIGID bright green 25 degree spray tip will minimize this risk..........
Cleaning exchanger bundles at refinery in Toledo. The washer unit heads were designed to pull themselves through the long tubes. One entered a guys body from the groin area and pulled itself upwards into his chest cavity. Buh-Bye
Old 05-29-2012, 04:49 AM
Bob Kontak's Avatar
I also think the thing looks like it's worth seven hundred and change.
One imperfection is the hose material is too hard. Coils up on itself more than I would like it to. Not a big hindrance and I am searching for criticisms.
FYI - You can buy a more flexible power washing hose at a higher PSI rating but I understand it is really expensive.
Also, as I noted above, I had the fuel injected Subaru. I would walk on it's own when running. The carb unit stays still.
I have an in-ground pool.. I had my walking fuel injected Soobie/RIGID unit near the pool. I was turned away washing like a fool. It took a swim. That is why I have the carb model.
Edit - there was a second person that depressed the engagement foot pedal but I understand he was distracted. Doh.
Old 05-29-2012, 05:07 AM
I kept the wand pressure nozzle handle/hose off my POS electric one I had ($99 and lasted only a year).
It works almost as good off a bare hose as it did when it was hooked up to the old pressure washer.
Old 05-29-2012, 09:04 AM
Evil Genius
Rusty Heap's Avatar
This large surface twirling double tip cleaner rocks the house for patios or driveways.
Shop Briggs & Stratton Rotating Surface Cleaner at Lowes.com
Life is a big ocean to swim in.
Wag more, bark less.
Old 05-29-2012, 09:42 AM
We should do a "show me your pressure washer" thread. I'd like to see some of the machines you guys are talking about....
Old 05-29-2012, 11:22 AM
Canucks Fan
The BIL and I split on a Honda/General unit a few years back, its good for our needs. I use Ridgid stuff at work, its top quality stuff.
Finn
From the Deep Dark Jungle
Old 05-29-2012, 11:30 AM
I just bought one of these and it is amazing!
1972 911T/S MFI Survivor
Old 05-29-2012, 12:35 PM
Evil Genius
Rusty Heap's Avatar
better blowing off and deep cleaning than a couple of Asian Twins?
Old 05-29-2012, 05:36 PM
