Work in Progress
Rich76_911s's Avatar
Running wire to my garage
The po of my house ran a wire over to the garage to run lights and an outlet or two, in an effort to make everything safe he buried it under an inch of dirt. the garage is currently on a 15 amp shared breaker with most of the outlets in the house.
Since I plan to do some more serious work in the garage I am thinking of an appropriate solution to bring more and safer power out to the garage. My idea right now is to add a 60 amp breaker to the panel in the house and run the wire about 55 feet to the garage where I will have a sub panel and a separate ground rod. I currently have a small compressor and a 120 miller welder in the garage that will be my big power draws. I'd like to get a bigger compressor down the road which is why I would like to have 240 volts and 60 amps to work with in the garage.
Would 4 wires (red, black, white, and green) of 6 awg be appropriate to bring 240 volts of 60 amp service to the garage sub panel? Here is the wire I plan on purchasing:
6 THHN Stranded Copper Black 2500' - 6THHNCSTRBLAX2500, AWG, , Building Wire, Cables, Cords - Platt Electric Supply
I've already dug the trench 18 inches and have PVC conduit ready to go. Can't wait to be able to run my little compressor without blowing the fuse in the house all the time.
Thanks for advice on the wire and any other thoughts you may have.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 06-07-2012, 07:51 PM
Zeke's Avatar
Go over to the Garage Journal forums where some of us hang out. The have a sub forum just for electrical in garages. Lots and lots of threads there about this exact thing. I think to save money on the feed, several of them are using mobile home cable.
Old 06-07-2012, 08:04 PM
Home Depot or Lowes sell UF-B direct burial cable by the foot. 4 conductor #6 as a romex cable instead of individual. Then your conduit is only for convenience and mechanical protection. Here we use corrigated 4" water hose as a conduit instead of needing a certified electrical conduit because the direct burial cable makes it redundant. It still might make it possible to pull the cable out to repair it if needed. #6 copper should be fine up to about 100 ft. I would talk to the local inspector first.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-07-2012, 08:21 PM
Work in Progress
Thanks Milt and John,
I had forgotten about those forums since jacks garage was posted over there. I will check them out tomorrow.
After nearly driving a pick through the previous owners wiring I decided to go with conduit for safety, and for easier future wiring options.
Old 06-07-2012, 08:30 PM
IIRC I ran 4 gauge wire to my garage, buried 18" in conduit. The main panel to sub panel distance was about 75 feet. I also ran a 70 amp fuse in the main panel, which might have been a bit much since I only have a 100 amp feed from the street. I figured that since I live alone, I could only use so much power at once!
Old 06-07-2012, 09:06 PM
jyl jyl is online now
jyl's Avatar
Home Electrical Advice? 240v In Garage
Is the thread on my project that was similar to yours. 60A to subpanel, 120 and 240 circuits (don't forget the switched ceiling outlets for lights and the unswitched for tools), separate ground (important), etc.
Old 06-07-2012, 09:19 PM
MBAtarga's Avatar
I'm not sure the separate ground rod at the garage is per code.
Mark
'83 SC Targa - since 5/5/2001
Old 06-08-2012, 07:54 AM
Serial Lurker
ledhedsymbols's Avatar
Send a message via AIM to ledhedsymbols
IIRC The subpanel shouldn't be grounded. You should have a ground conductor back to your service and it should be bonded there. Your neutrals should float in your subpanel.
Does anyone know where the love of god goes when the waves turn the minutes to hours?
Old 06-08-2012, 07:59 AM
Unregistered
sammyg2's Avatar
220, 221, whatever it takes.
You guys are slipping.
Old 06-08-2012, 08:41 AM
Zeke's Avatar
If you have a spare 10 minutes, read this:
Grounding Rods - Attached vs. Detatched structure - The Garage Journal Board
Goes to show you that there will be debate on whether water rolls off a duck's back.
Here's one that has it all:
http://www.garagejournal.com/forum/showthread.php?t=147659&highlight=subpanel
Old 06-08-2012, 08:49 AM
