vibe
Wow, I just happen to save the vibrator out of my dad's old lounge chair.
How's this look to you? http://forums.pelicanparts.com/uploa...1339802789.jpg http://forums.pelicanparts.com/uploa...1339802800.jpg http://forums.pelicanparts.com/uploa...1339802809.jpg |
too big...thanks
Infant bouncy chairs? Used to soothe the little one to sleep. Often have different frequency settings (though they're fixed, not variable).
Occupational/Hand therapists also have hand-held vibrating massagers they use for desensitization and scar massage.
building a prototype, but will need to source for production. can't believe I can't find a supplier in the us. thanks again, this is along the lines I'm looking for. |
this motor is the size of a spool of sewing thread.
nice call Noah! what a great resoursce this board is. |
Contact Todd(9dreizig). He sells stuff along these lines....
The printing industry uses something called a jogger. The idea is that a lift of paper is vibrated into a corner. This is the first step before the lift (or stack) goes to the trimmer then to assembly.
They come in all sizes to jog paper from 8.5 x 11 to 30 x 40. Maybe you can find a used one. http://forums.pelicanparts.com/uploa...1339846698.jpg |
How about something like this?
Amazon.com: Dayton Audio TT25-16 PUCK Tactile Transducer Mini Bass Shaker: Electronics |
I'm going to play with the bouncy seat motor today. Might add a variable controller to it so I can give customer ability to dial in the right feel. Thanks. |
if you decide to ramp up the power later... I got this yesterday.. said in Tim Allen's voice...more power! uhuhuh
http://forums.pelicanparts.com/uploa...1339877376.jpg |
We had a paint shaker like that.... make damn sure you clamp the cans tight, otherwise it will chuck them across the shop, and make everything within a large radius british racing green.....
I Have no reason to shake paint. I just like old junk
thought about this thread tonight after I took apart a couple old electric shavers to see how they work. I took apart a battery powered one and also a a/c powered one but the concept is the same. a cam on the shaft makes the head vibrate. not sure if this would work for your application but here's pictures of both.. I also have one of those cheap seat cushions with several vibrating motors I"ll have to take apart now... if I can find it
http://forums.pelicanparts.com/uploa...1340254887.jpg http://forums.pelicanparts.com/uploa...1340254981.jpg http://forums.pelicanparts.com/uploa...1340255049.jpg |
Or you could just hook up an old Harley motor: noise and shaking!
Sorry. :D Les |
John,
for my prototype, that's basically what I have except I added a. 1.5" diameter disk to the shaft so I could place some more weight further out. I'm going to build my own vibrator with a stepper motor. client is happy with results so far. |
okay
| All times are GMT -8. The time now is 11:07 AM. |
