chocolatelab's Avatar
Originally Posted by Noney View Post
I'll run that by my wife.
Probably go over like a fart in a space suit.....
There was a thread running for awhile with saying like this in red, anybody remember its name.
Sorry about the hijack.
I would recommend though looking into xeroscape. Change planter sprinklers to drips. No over spray on the house.
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 09-26-2012, 08:59 PM
Free minder
Aurel's Avatar
Hydroxide ions will do that. What happens is ferrous iron is clear in your water, and becomes ferric (rust) when it dries on the ground in presence of oxygen. If you oxidize it in the water, it forms ferric hydroxide which precipitates. Oxidizing agent can be hydrogen peroxide, chlorine, ozone..
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 09-26-2012, 09:01 PM
If it were me I'd also try thinking outside the box. I'd think about installing something like a drip system or bury drip system like tubes with small radius sprinklers that don't spray high enough to get spray everywhere. I'd try to resolve it that way - or some other way - rather than chemical treatment.
Marv Evans
'69 911E
Old 09-26-2012, 09:52 PM
A930Rocket's Avatar
This. ^^^
Our wells were usually 200-250 feet deep to prevent iron deposits.
You must have a "shallow well". Iron content in well water is variable depending on depth of well. Not everybody who has a well has iron. I bet you could re-jet a new well at a different depth - and get away from the iron issue. Or achieve less iron in your well water.
Now you can't just use the same spot the existing well is in. It would have to be at least a few feet away - preferably at least 5' or more away.
Have you talked to any well drillers in your area? I've jetted wells myself in neighborhoods which have iron issues and my wells worked great and did not have iron (to any great extent anyway).
I usually go down about 20' but you should measure your well depth and try to go more shallow.
Old 09-26-2012, 10:19 PM
Senior Member
This. ^^^
You guys are so lucky.
Ours hit water at 520 feet. To get and keep a good head pressure they continued drilling and stopped at 940 feet. Almost ever well in our are is at least 900 foot.
Old 09-27-2012, 08:04 AM
A930Rocket's Avatar
Well, since are at sea level, we don't have far to go.
Old 09-27-2012, 08:15 AM
tharbert's Avatar
When I was in Shreveport, our house had an iron removal system. It was a simple in-line filter with manganese-coated aluminum silicate above a manganese-treated green sand bed. It back-flushed with a solution of potasium permanganate.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 09-27-2012, 08:44 AM
Turgid Member
Noney's Avatar
The house was built in 1966 and the well was installed at the same time, so I have no idea how deep it is. Baz, from what you are saying I might be able to cure the problem by digging another well but I'm guessing that's going to be some big $$$, probably more than I want to spend on this rust problem.
Everybody in my neighborhood that has a well has one of the tank systems that you pour this into:
It is colorless and odorless and if you use enough of it, it works fairly well, but again it's $10 a gallon and I can use up to 8 gallons a month during the dry season. I guess I was thinking I could make my own concoction, but from what I'm hearing I might be better off getting some kind of filtration system or re-thinking the water delivery method.
I appreciate the input, gentlemen. I'm off to do more research and re-think this thing....
'87 Carrera
"Man who go through airport turnstile sideways going to Bangkok"
Old 09-27-2012, 10:49 AM
tharbert's Avatar
You could just dump some potasium permanganate down the well too...even if you drink it occasionally. It's used in potable water treatment. It oxidizes iron, manganese, and hydrogen sulfide into inert particles.
72 911T 2.4 MFI
Old 09-27-2012, 10:58 AM
Regenerated User
72doug2,2S's Avatar
Do you have pictures of the rust. A nice mellow yellow might look very nice, you'd just need an even application to pull it off.
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 09-27-2012, 11:02 AM
Turgid Member
Noney's Avatar
The well is only used for irrigation, so that might work. Once I get the water tested, how do I determine how much PP to use?
'87 Carrera
Old 09-27-2012, 11:09 AM
