mercury poisoning, had to go to NY to get cured
Drove to New York and trailered back a 1966 Mercury Comet, has a 289. Will need some work but it's pretty straight. It was a long haul for the old truck.
1970 911T XR400 93 F150 |
Friend of Warren
Nice. Are those Keystone wheels?
Kurt V No more Porsches, but a revolving number of motorcycles. |
Cooooooooool!
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
The Unsettler
Looks like it.
I hate seeing old American Muscle running around on new 19 in blinged out rims. Just looks wrong.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Verry cool car! I had it's FoMoCo sister, a '66 Fairlane GT 390 in Highland Green.
" Formerly we suffered from crime. Today we suffer from laws" (55-120) Tacitus |
Thanks for the comments. Yes, those are Keystones. I plan to keep them but I will get rid of the hood pins.
Very cool car Steve. Those cars had great lines. What are your plans for it?
(I had a 67 Fairlane ragtop)
O2 In Sully We Believe |
That's a sweet ride. Congrats!
entertaining the idea
Guards red?
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
Banned
I like it. I like the hood pins and the keystones too.
Senior Member
Very nice!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Formerly reformed
Love it. An old friend of mine had what I recall to have been a '67 LTD with a 429(?). Stacked lights rock.
1968 911P (Paperweight) |
too much car for too little of an engine.
My choice would be a 351 W with a 408 stroker kit, afr 225 heads, Edelbrock Air Gap RPM intake, a cam around 286/296 with a centerline of 112 and a lift in the .510 range The carb should be the 825 to 850 range Skip the 4 spd and drop in a Tremec with 5 spd/overdrive Rear gears around 3.90 to 4.11's will wake it right up but still let you cruise at 75-80 around 2,800 rpm (150 mph will be in the 5,ooo rpm range)
Jim has a good plan...and you'll be amazed how much less expensive Detroit performance is...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
the only way I would keep the 289 would be TWINNS!
Turbos, and lots of gears that's a 3.400 pound car...kinda like a new 911 a240hp at the flywheel aint goin'a move sheepdip!
Senior Member
Agree with your idea on going bigger but how about a 428 or so? ![]() Joe A
REBUILT USED NASCAR WINSTON CUP ENGINE-BUILT BY ROUSH YATES ENGINES, DYNO TIME ONLY
Engine 103 Configuration: C3 - Open (non restrictor plate) Block Number: Y302 Crank: 3.450" Stroke - Serial Number Y493 Bore Size: 4.0618" Connecting Rod: 6.2" Lentz with .867" wrist pin Cylinder head: C3 Roush Yates Valve Covers: 1 piece welded Aluminum Intake Manifold: Ford Racing X351 Bellhousing: QuarterMaster Clutch: QuarterMaster V7.25 triple disc with Tri-lite bearing Oil Pump: Weiss 6 stage dry sump Horsepower: Approx. 830 $13,500 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Thought in American iron that "bigger is better?"
Agree with your idea on going bigger but how about a 428 or so? Joe A __________________ Joe have you EVER worked on a 428? I will never own a FE series motor! Unless it's a 427 just due to the fact that it's a 427 429/460 motor will fit in the Cyclone merc's engine bay! that's an engine. None of Hey, we have to take ALL 16 pushrods off to change the intake manifold! Nor does the LIMA series 429/460's have that STUPID little 1 1/2" long hose that's between the water pump and the block that you can't change with out removing the water pump! my '66 fairlane was a 390 car, same engine series "FE" as the 428 My Dad built some wicked FE motors that lapped Riverside and Ontario Speedway fairly well. I used to pull 7/16" studs out of the cast iron heads on my 390! FE engines rocker arms rotate on a shaft that runs the lenght of the head I broke a couple of shafts on that car as well. I broke the fingers on the Mcleod clutch I broke the output shaft on the toploader I broke the rear shocks off of the car (I might have lifted the front end off of the ground on that launch
PRO Motorsports
Actually the '66/'67 Fairlane and Comet with a small block Ford are under 3000 pounds. They move out quite nicely with a hipo 289.
I actually think they are too flimsy a car for big block power without some reinforcement. It's a unibody car with very little structure. They don't have beefy longitudinals like a 911. |
