Jaybird12
Jaybird12's Avatar
911 door handle/ lock problem
Sorry. Didn't know where to post this. 1975 911 Targa. Driverside door. Whenever I enter the pull up style door lock falls slightly and locks. Any idea what is worn or broken here?
Jason
1975 Euro Spec 911S Targa
1987 VW Westfalia Camper
2006 Subaru Forester
Old 10-09-2012, 01:40 PM
FYI here's what it hooks to
As mounted
1972 911T/S MFI Survivor
Old 10-09-2012, 02:38 PM
<insert witty title here>
Christien's Avatar
If the pull-up piece on the sill is just falling without any pressure being put on it, then yes, it's likely the latch which is the problem, as that's where the tension comes from. Though it's possible the problem is elsewhere. First thing to do is pull off the door panel and have a look around. If you do have to replace the latch, it's no fun. Cheap, but a PITA.
Old 10-09-2012, 04:42 PM
Definite PITA if you have to remove it completely.
But, many of the lock's components snap together like throttle linkage. There are some white plastic/vinyl clips that can become brittle and fail. I believe I ordered them from Pelican and might even have an extra if they are NLA. Lemme know.
Old 10-09-2012, 05:55 PM
Jaybird12
Jaybird12's Avatar
Sounds good. I'll tear it apart this weekend and see what state its in. If I need the plastic bits ill contact you. Thanks everyone for your input.
Jason
Old 10-11-2012, 02:54 AM
