LED light bars... Shop LED Cabinet Lighting at Lowes.com
76' 911s Signature Edition |
'06 Cayman S '16 Cayenne '08 Audi RS 4 |
Some people must have missed the 'Cheap' part of my question.
Or maybe I have to say 'super-cheap'. It's all relative... I am looking into 5050 LED strips. They seem decent.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Well, you pay cheap, you get cheap. Its an electrical component after all, do you really cheap? IN the long run, the hassle to change and repair under counter lighting is a PITA. A few hundred vs a few bucks over a hundred is worth it IMO. I never do cheap, because we have to responsible for them in the any years to come. Not just one.
I used 1/2" diameter clear incandescent rope lighting. For the countertop lighting, I stapled clear plastic U-channel to the underside of the cabinets (2 pieces, 1 front & 1 back) and the rope is a friction fit in the U-channel. The upper cabinets don't have a soffit, so there's a 24" space between the cabinet tops and the ceiling. My wife has various decorative crap up there, so I also put the U-channel and rope lighting on the inside of the crown moulding that's around the top of the cabinets.
The switches control outlets that are in the wall just above the upper cabinets. The lower rope lighting cords pass through the inside of the upper cabinets and everything just plugs into the outlets. Every couple of years I replace all of the ropes, but they're very inexpensive. It's a very low profile system and gives very even natural incandescent light to the countertop and decorative crap areas. |
Does the rope light actually do anything as far as task lighting? Or it's just for appearance?
I would say adequate, certainly better when you turn it on than when it's off. It would be easy enough to buy a length of it and test it out. It's probably plentiful and on sale right now as well. Or maybe they're pushing LED rope now, I don't know. I ended up buying a spool of the incandescent rope for replacing the original "Christmas" rope that I had installed originally.
