Insert Tag Line HERE.....
Ford/mercury diagnostics help
FIL has a 2000 merc grand marquis and has a problem with the Electronic Automatic Temperature Control. When put on 65 it blows cold, when put on 68 or higher blows hot. So it's either full cold or full hot, no in between. This leads me to believe that the blend air door is working, just not being controlled properly? I ran the eatc self diagnostics and the unit has no fault codes so I'm leaning towards the control head itself. Anybody have any exp. with these?
Not in a grand marquis, but I recently had an explorer eat my lunch with a similar problem. ( not same symptoms as yours though) . The components location is what makes it so tough to diagnose. Blend door actuator failure is pretty common on this era ford vehicles though.
No left turn un stoned |
Member
On GM cars there are small servo motors that move the doors. The plastic gears strip on the motors and the doors go full open or full closed.
Another crappy engineering design on the planned obsolescence list......... Sorry i cant be of any real assistance.
Paul 91 964 C2 Targa sold (shipped back to the fatherland) 09 Cayman PDK 17 Titan 55 Sunbeam S7 Deluxe 70 Triumph Bonneville |
Hell Belcho
Had this same problem with my grandpa's Grand Marquis. I took the control unit out and cleaned up the electrical connections, re-seated them and no more problems.
Saved by the buoyancy of citrus. |
Burn the fire.
FORD has a simple procedure for this: Trade it in at a dealership and get a new(er) vehicle. At over 10 years since its manufacture date it has exceeded its expiration date.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
