LinkBack Thread Tools Rating: Thread Rating: 7 votes, 2.29 average.
AutoBahned
RWebb's Avatar
Disk Permissions - mac
I found some places where "permissions differ" on my McMini's startup disk. It is only ~ 3-4 months old.
Should I tell it to repair them or leave it be?
Old 11-30-2012, 03:25 PM
The Unsettler
stomachmonkey's Avatar
Let it fix them or leave them.
Permissions problems are made out to be a bigger deal than they really are.
Unless you are having issues with the machine you don't really need to worry about them.
"I want my two dollars"
"Brandon Won"
Old 11-30-2012, 03:28 PM
AutoBahned
RWebb's Avatar
only issue is it seems sluggish
Old 11-30-2012, 03:38 PM
jyl jyl is online now
jyl's Avatar
Repair them, doesn't hurt and doesn't take long.
Install an SSD if you want frisky!
Old 11-30-2012, 05:00 PM
id10t's Avatar
When the permissions start with an l then it means that it is a link (either symbolic or hard) which is basically a pointer to another file. Links should always be 777 (owning user, owning group, and anyone on the system have read, write and execute permissions on it) since the actual/effective permissions are on what the link is pointing to.
So... chmod a+rwx /path/to/the/link or chmod 777 /path/to/the/link
The ones that should be "user 0" or "group 0" mean that the owning user or group should be root (or wheel or whatever OS X calls the superuser account)
Old 12-01-2012, 07:13 AM
Scott R's Avatar
I forgot I had this list for you, it's nothing special really I just asked one of our desktop support guys and he sent me this, likely from some internet source.
For performance issues, there are a few things you can check before resorting to hardware upgrades:
Remove any non-essential apps from System Preferences > Accounts > yourusername > Login Items
(Lion users: System Preferences > Users & Groups > yourusername > Login Items)
Remove any non-essential items from /Library/LaunchAgents/ and ~/Library/LaunchAgents/
(Lion users: In Finder, click Go > Go to Folder > then enter the path)
Remove any non-essential items from /Library/StartupItems/
Remove any non-essential widgets you may have running, and uninstall any you don't need anymore.
Launch Activity Monitor and change "My Processes" at the top to "All Processes", then click on the CPU column heading once or twice, so the arrow points downward (highest values on top). Then look to see what may be consuming system resources.
Launch Activity Monitor and click the System Memory tab at the bottom to check your page outs. Page outs are cumulative since your last restart, so the best way to check is to restart your computer and track page outs under your normal workload (the apps, browser pages and documents you normally would have open). If your page outs are significant (say 1GB or more) under normal use, you may benefit from more RAM.
Make sure you're not running any 3rd party antivirus app, as many of those will drain resources, reducing performance. They're not needed to protect your Mac. For more information, read the Mac Virus/Malware FAQ.
Install ClickToFlash (Safari), Flashblock (Firefox) or FlashBlock (Chrome) to control which Flash content plays on websites.
Find your Flash version and make sure it's the latest version available.
Use the YouTube HTML5 Video Player for watching YouTube videos, when available. (May impact fullscreen viewing. See link for details.) Not all YouTube videos are available in HTML5, but when they are, it will reduce demand on system resources.
Ad-blockers such as GlimmerBlocker will reduce the resource demands of loading webpages.
Check your DNS settings by reading this.
Maintain sufficient free space on your hard drive. 10% free space is good. More is better.
Disable or remove unnecessary or corrupt fonts using Font Book, which is in your Applications folder.
Turn off resources like Bluetooth or WiFi, when you're not using them.
Go to System Preferences > Dock and select Minimize using: Scale Effect. Uncheck "Animate opening applications".
Make sure your built-in Mac firewall is enabled in System Preferences > Security > Firewall
Uncheck "Open "safe" files after downloading" in Safari > Preferences > General
Uncheck "Enable Java" in Safari > Preferences > Security. Leave this unchecked until you visit a trusted site that requires Java, then re-enable only for your visit to that site. (This is not to be confused with JavaScript, which you should leave enabled.)
Be careful to only install software from trusted, reputable sites. Never install pirated software. If you're not sure about an app, ask in this forum before installing.
Never let someone else have physical access to install anything on your Mac.
Always keep your Mac and application software updated. Use Software Update for your Mac software. For other software, it's safer to get updates from the developer's site or from the menu item "Check for updates", rather than installing from any notification window that pops up while you're surfing the web.
Check the above for all user accounts that may be logged in. Log out any user accounts that aren't being currently used.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-01-2012, 09:31 AM
