LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.50 average.
"O"man(are we in trouble)
widgeon13's Avatar
Watch battery question
My wife has a bunch of cheap watches that she wears periodically (one at a time), sort of costume stuff. Three of them have different batteries but the batteries are all energizer, all 1.5 volt, silver oxide and all the same size. Seems to me they would be interchangeable. ARE THEY INTERCHANGEABLE?
Because I've taken all three out of the watches to be replaced and now can't remember which went where. I haven't gotten the new batteries yet but would like to just get three of the same and not have to hunt for the three individual model numbers.
Actually, I'd like to throw out all three watches and that would solve one problem but create another.
Old 12-04-2012, 01:30 PM
Oracle's Avatar
There are about 3 o 4 common watch batteries, the size is different so each slot pretty much defines the battery to use.
On the other hand just put them on and if the watch dies so be it.. this is your opportunity to get her xmas present and possibly get some lovin' points. ;-)
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 12-04-2012, 02:05 PM
Oracle's Avatar
-Oscar Wilde
Old 12-04-2012, 02:08 PM
Damian in NJ's Avatar
1.55V silver oxide batteries of the same width/diameter are interchangeable. Each brand uses their own code numbers, as well as codes to determine the date when the battery was manufactured.
Watch Battery Conversion Chart! Battery Cross Reference Guide! Cell Conversion Chart for all Watch Batteries, listed by Type, Brand, Size, Model Number. Batteries for Watches, Calculators, Remote Starters. Lithium, Silver-Oxide, Mercury - Jewelry-Sec
95 968 Cab, Speed Yellow, Kinesis Supercups, Promax chip, Big Reds, SS brake lines, 5/35 brake bias valve, H&R sport springs, mo30 sway bars, LSD, Brey Krause control arm brace, Dynatech billet strut brace, Cargraphic 100 cell cat and ss exhaust, Club Sport steering wheel, short shift, sport seats
Old 12-04-2012, 02:09 PM
Oracle, there are way more than that commonly used.
Old 12-04-2012, 02:13 PM
Petie3rd
Mrmerlin's Avatar
Using the chart p[osted see if all of the batteries you have are in fact the same, if not,
I would suggest to put on your glasses, and look carefully at the batteries
if the battery has a different number it will also be sized differently,
ref the chart to cross check different MFGs
I have a bunch of battery operated watches and,
i make a list of each one and the battery # that came out of it.
of course every watch I have,
has a different sized battery
Old 12-04-2012, 02:31 PM
No, identical batteries from different vendors will have different numbers. Often times you'll see the diameter of the battery printed in the battery well. What it won't tell you is the thickness.
Old 12-04-2012, 02:46 PM
