Anyone try one of these garage air line kits?
I thought we had a thread about this already but I can't find it. I priced out doing this in copper with brass ball valves and fittings it's around $400. Or I can get the poly kit for half the price.
Anyone tried this? M7500 RapidAir MaxLine 3/4" Compressed Air Piping System Master Kit
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Subscribed. I've always wondered why people don't use actual airhose as the air-line. I need a bike air supply in my backyard. I want one of those presta inflator guns. Pumping gets old.
poof! gone |
Friend of Warren
Because the air hose itself lacks sufficient volume to really carry much air for long distances. With 100 feet of hose you might have 100 psi at the compressor and only have 60 psi at the end of the air hose. Ok for inflating a bike tire, but would suck for using any air tools.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Well this is 3/4" and is rigid vs. a flex air hose. It has great reviews, and the price is $199 on amazon. I might just grab it since it's so cheap.
I installed something very similar in a mid sized body shop with great results. Can get expensive but very nice to work with. Rubber airhose will deteriorate over time.
R.I.P.
A lot of people use PVC pipe. Run 1" for the first 20ft then 3/4" the rest of the way.
78 in a '71
I understand that there is an explosion/failure danger with PVC pipe.
On glide path...... 1971 911 T Targa 2013 Ford Fusion Titanium AWD 1982 Volvo 245, 1996 Ford F-150 |
Oxygen barrier pex tubing and sharkbite connectors. You can get everything at Lowe's or Home Depot.
You can use the crimp tool on them also. 3/4 in. x 100 ft. Oxygen Barrier PEX Tube-U870O100 at The Home Depot
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
There is SIGNIFICANT failure danger with PVC pipe. Don't do it. ASME and OSHA have specific mandates against this for a reason.
You can use thick-walled HDPE tubing (3/4" OD tubing runs ~$0.45/ft) and push-connect or compression fittings to do this safely. The only PEX-like product I'm aware of for compressed air is Duratec by IPEX. Asahi markets a fused HDPE air line (called Airpro). |
Canucks Fan
Most white PVC is scheduale 40 or sked 40, the gray sked 80 is the pipe to use if your going the PVC route, its expensive but won't break.
Finn
From the Deep Dark Jungle |
Bill is Dead.
I bought a kit like this over the summer, but have not installed it yet.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Well it's $139 for the kit I need with the appropriate compressor manifold. Then I need to add a "T" and another outlet for a hanging hose reel I have. So I guess I'm going to do it. Should be enough hose in the kit according to my tape measure.
Regardless of wall thickness, please don't use materials with brittle-fracture characteristics (PVC, polypropylene, etc) for compressed gas service. They do fail, they fail explosively, and people get hurt.
19880520 The Use of Polyvinyl Chloride Pipe in Above Ground Installations Cautions Areas Polyethylenes, ABS, steel, rubber hose - all make better air line. |
Senior Member
We used PVC piping around the garage and its worked for almost 10 years now. First off it rarely gets below 50 here and no matter what its always left unpressurized and when turned on, its done slowly.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
R.I.P.
must be a northern thing.. Most shops down here in Florida that I have been in use PVC. But I can see the cold-brittle issue
Did you get the memo?
PVC will also become brittle in sunlight. So the amount of exposure that it gets in your garage could also become a factor.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
závodník 'X'
Harbor Freight has a large variety of lines, ball valves, couplers for a fraction of the cost posted above. I agree going with the large i.d. for volume, especially for air tools and HVLP spray guns.
“When these fine people came to me with an offer to make four movies for them, I immediately said ‘yes’ for one reason and one reason only… Netflix rhymes with ‘wet chicks,'” Sandler said in a prepared statement. “Let the streaming begin!” - Adam Sandler |
