F-111 Belly Landing
If you're into special airplanes even a little, here is a video I'm sure you'll enjoy. These Aussie guys do a remarkable job getting their aircraft back on the ground with a minimal amount of damage. It could have very easily gone the other way. Also, notice early in the video there is a sequence showing a F-111 dumping fuel with the afterburners on lighting up the night sky. Something a little unique to the F-111.
The airplane was originally designed to land on a carrier deck so the gear structure is very strong. Even landing on a long runway you just maintain 10 degrees angle of attack until the runway stops your descent. Because this is the way the airplane was designed to be landed it felt just fine inside the airplane, but for an observer outside the aircraft it looked like you forgot to flare and really clobbered the landing. I don't know if metal fatigue was a factor in this accident but they are fortunate the wheel fell off upon liftoff and not while accelerating down the runway in full afterburner. Using the tail hook to catch the arresting cable was a great idea, as you will see.. Arresting wires on runways are not like the ones on the flight deck of a carrier. They provide less resistance and let you decelerate over about a 900 ft. range, something you wouldn't have room to do on a carrier. Pretty neat landing and luckily no fire. Check out the 7:05min. video below: It did not want to embed. http://www.youtube.com/watch?feature=player_embedded&v=KIyYK9oz9Go
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
A buddy since chilhood was an F-111 pilot...Thank for the video, I'm passing the link on to him.
The USAF retired the F-111. Are the Brits still flying it? Anyway, Jimbo flys this these days..
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Ubi bene ibi patria
The RAAF was the last air force to use the General Dynamics F-111 "Aardvark". They retired their's in 2010
Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras Last edited by Hawkeye's-911T; 01-25-2013 at 04:23 PM.. |
Nice video.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
I see you
Very "Sully" like control.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
The grass sure looks a lot softer!
'95 993 C4 Cabriolet Bunch of motorcycles |
Did you get the memo?
Very impressive.
But the grass did not have a cable for the tail hook.
wow... I wonder if the airframe had to be scrapped?
Silver '88 RoW Carrera Grey '06 A4 Avant |
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Make Bruins Great Again
True but the uneven surface would possibly cause the plane to catch an edge and flip. Better to have a hard smooth surface to slide on.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I read the title as F-117 Belly Landing and just freaked out.
Still impressive though.
M |
F-111 Dump and Burn - YouTube
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
Gon fix it with me hammer
Black is the New Black
The aircraft was repaired and returned to service for 3 or so years. The wheel that departed travelled across the airfield to the buildings visible in the video where upon it struck and wrote off the CO's car.
I bet someone in the maintenance dept got fired for loosing a wheel.
Probably used the wrong nuts with new , wrong offset wheel, like that dude who lost all 4 wheels of his RX7 at an autoX
No, the stub axle failed due to a fatigue crack. The wheel took most of the axle plus the brake unit with it.
I was just kidding bout the nuts , but did you used to work these planes?
No, didn't work on them. I was a Flight Engineer on C-130's and AP3C Orions . The Australian Airforce is pretty small 13000 people or so. This incident was very thoroughly discussed in crew rooms across the country. Partly because the pilot involved was very junior but handled the emergency like an old hand and partly because, in an Airforce the size of ours you can guarantee , at least one of your squadron mates knew the pilot .
