Registered ConfUser
Floor jack needs Viagra - Help -
I have an old 2.5 ton floor jack. Has always served me well. Probably 20 years old. Weighs a ton!
Seems to have lost it's lift. Will raise the car a few inches before pumping the handle does less and less. There's a slotted cap and an allen-head cap. Both are full of hydraulic oil, so couldn't add more. Is there a trick to reviving these things, or is it time for a new aluminum one?
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
They won't take much fluid without operating the handle. You need to open the fill cap, and add a few drops of fluid, pump the handle, few more drops, pump the handle, rinse repeat. Run it up to full lift, drop it , and do it again. May take a few cycles. '
From your description , sounds like low fluid.
No left turn un stoned |
What Fred said.
Get some hydraulic jack oil and add it as you pump the handle.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Mike,
Try adding more jack oil as you move the handle up and down. Good luck!
Old dog....new tricks..... |
Registered ConfUser
Did that, but will try again. Didn't seem to be low. I added oil and it quickly overflowed the opening.
Try, try again! Thanks for the info guys. |
If you end up replacing I highly suggest staying away from the cheapo aluminum jacks. Mine was just junk. Now the steel ones at Costco I've had good luck with and I believe our host sells a good aluminum one.
The seals need replacing.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
