Shaun @ Tru6's Avatar
Bending 1 1/4 EMT
I need to do 14, 45 degree bends with 1 1/4 EMT. 1 inch is fairly easy with a Klein bender, can't find a 1 1/4 one locally.
Will one of these work? (pic below)
Hydraulic Pipe & Tube Bender - 12 Ton
I ask because this one says not for conduit, but seems to be the same, just air operated. Anything else to consider?
Northern Industrial Air/Hydraulic Pipe Bender — 12-Ton | Pipe Bar Benders| Northern Tool + Equipment
Tru6 Restoration & Design
Old 02-16-2013, 01:18 PM
Why not just have an electrical contractor bend them for you using his tools? Probably cheaper than buying a tool you'll never need again...
JR
Old 02-16-2013, 01:56 PM
That will kink the thin walled stuff... We have one, its nearly useless....
Old 02-16-2013, 01:59 PM
78 in a '71
mossguy's Avatar
JR
Any reason to buy another tool is a good reason!
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 02-16-2013, 02:05 PM
DByers's Avatar
You can also buy 45d bends at most electrical distributors. We sell them but I'm on the west coast.
If you are trying to have the bend at a certain measurement on the 10' piece then as suggested find a good EC to bend them for you, cheaper that way. I have a local EC I use all the time for custom offsets and such.
As Sydney mentioned, that tool will crease or kink the EMT.
Good luck
Dan Byers
Old 02-16-2013, 02:11 PM
How much do you weigh?
Bending 1 1/4" EMT - YouTube
Rick
88 Cab
Old 02-16-2013, 02:12 PM
Yes! and if I get a "single use" tool, it ends up getting used more. I've gone through three blades on a 14" Milwaukee metal chop saw.
But on getting an EC to come by, that's a good idea and I'll call a few locals on Monday. thank you.
Old 02-16-2013, 02:59 PM
I'd have them make the bends at their shop, then go pick them up. Cheaper, especially if you're a little flexible on timing and they can use this task to kill an hour at the end of a day for one of their guys. Assuming you can haul whatever length you are needing...
JR
Old 02-16-2013, 03:04 PM
good idea JR, the wagon hauls anything.
Old 02-16-2013, 03:36 PM
Serial Lurker
ledhedsymbols's Avatar
Send a message via AIM to ledhedsymbols
A one inch rigid conduit bender is equal to one and a quarter EMT. They aren't cheap and require a substantial amount of weight to bend with. Either get factory bends from the supply house, usually you can get 15 30 45 and 90 degree bends easily, or ask a local shop. It will take just a couple minutes for a good wireman with a power bender and it will look better with tighter radii. I'm about 5'9" and 175 lbs. 1 1/4 " EMT eats my lunch!
Does anyone know where the love of god goes when the waves turn the minutes to hours?
Old 02-16-2013, 09:24 PM
A930Rocket's Avatar
Muffler shop?
Old 02-17-2013, 01:44 AM
You do not have permissi
john70t's Avatar
Isn't there a trick to it such as filling the pipe with sand or a spring?
Old 02-17-2013, 04:37 PM
Greenlee bender is the right way.
Old 02-17-2013, 07:07 PM
Called 3 places, 1 couldn't do it, 1 said $10 per pipe, other said $20 per pipe. The one that couldn't do it, their hydraulic bender broke and they just use fittings and couplers these days.
So this is coming in the mail, all of $63 shipped, can use my jack arm and will probably weld-up a jig to use a come-along and make it easy. We'll see.
Old 02-18-2013, 12:11 PM
Super Moderator
cstreit's Avatar
The harbor freight/northern tool dies for the hydraulic press are very crappy. Unless you pack with sand, you will get kinks....
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-18-2013, 01:14 PM
This is what I use to bend all my tubing.
Von
http://vonsmog.com
73' 911T Coupe, 76' 911S Targa
73'& 80' Mercedes Unimog DoKa
59' Austin Healey 100-6
Old 02-18-2013, 01:55 PM
Bender came in yesterday, jack handle fits but loose. I won't say it was easy, but it definitely wasn't hard. 13 more of these to go, done in 2 jobs, won't be bad.
Old 02-23-2013, 12:27 PM
Why not go find about a 5' piece of pipe that fits it?
Old 02-23-2013, 03:46 PM
jack handle is free.
Old 02-23-2013, 04:12 PM
