cycling has-been
bkreigsr's Avatar
Rod Builders: guides on top or bottom for spinning rod?
I think I screwed up my last spinning rod and put the guides on the bottom of the spine. I might have to switch the handle to a casting.
Like to hear the brain trust consensus.
Bill K
Old 02-28-2013, 06:43 AM
78 in a '71
mossguy's Avatar
All my spinning rods have the guides on the bottom.
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 02-28-2013, 06:48 AM
vash's Avatar
99% sure the guides go on the same side of the rod as the reel. so on the bottom.
and the guides are different. casting, they are all low profile and smaller. spinning, they ride away from the rod, and start HUGE and taper down smaller..
poof! gone
Old 02-28-2013, 07:22 AM
Thanks, Vash.I was having trouble with the top/bottom thing.
Thankfully I find my use of casting rods has not been upside over for the last 40 years......that would be guides up.
JPIII
Early Boxster
Old 02-28-2013, 07:32 AM
GWN7's Avatar
I've been changing my spinning rod tips to fly rod tips for about 35 years. I find it makes the rod more sensitive to light bites.
Bunch of old cars
Old 02-28-2013, 07:49 AM
cycling has-been
bkreigsr's Avatar
good tip
Old 02-28-2013, 07:58 AM
id10t's Avatar
One of the micro sized spinning reels with 2-4lb test line (or similar diameter for braided line) on a 8 or 9 foot 6 or 7 weight rod is a *great* combo for flinging little tiny spinners and such. Lots of fun to catch pan fish and small bass on.
Old 02-28-2013, 08:00 AM
GWN7's Avatar
When jigging you can actually see the bite before you can feel it. I take the stock handle off a factory rod and put a full cork handle on. Then tape the reel to the handle. The cork fits my hand better.
Bunch of old cars
Old 02-28-2013, 08:11 AM
In the rod building class I took the instructor stated the spine is always on top. The guides go on the bottom opposite the spine when building a spinning/casting rod. The guides for a boat rod go on the spine.
Old 02-28-2013, 08:25 AM
oldschoollear's Avatar
Some of the rod makers I follow spiral guides around the pole; weird to me, but theses guys love ir
Old 02-28-2013, 11:18 AM
