Banned
usb3 memory sticks vs a SSD/HD
I have noticed usb3 memory sticks are cheaper then the same volume in a SSD/Hd esp in a 32g or 64 or even 128g a stick
like about 1/2 cost per G
and the claim to run near the same max speeds sata3 = 6G , usb3 = 5G
but max is not real world data transfer rates
but MS in windoz 7 or earlier copy protection will not allow the OS to be run from a usb[1-2-3] memory stick
w8 may work [but I donot like w8] do to the timing of the usb drivers loading
do SSD's use the same or a different memory type then the usb3 sticks ?
can linix or other O/S run off a memory stick is stead of a HD/SSD
could several usb3 sticks be used to get more storage at the same time
can a game or other program live on a memory stick [only plugged in when in use]
with out taking up SSD/HD space ?
is there a way to get all new data to only go on a memory stick and NOT on to a SSD/HD
leaving only the O/S on the HD and never anything else ?
I like the idea of useing different O/S's with a simple memory stick swap
and having a totally eazy removable device with all my data on it
are there any other type of non-usb memory sticks for firewire, thunderbolt, or sata3 ?
that could allow a w7 boot from the stick ?
Old 05-23-2013, 09:16 AM
winter-hater club member
nynor's Avatar
linux, at least the version i am playing with, will boot from a USB thumb drive.
"COOL PRIUS!" - Nobody Ever
Old 05-23-2013, 09:19 AM
nynor's Avatar
a short search seems to indicate that Win7 can be run from a thumb drive:
How to Install and Run Windows 7 from USB Flash Drive
edit:
and here:
http://www.wikihow.com/Create-Bootable-Windows-7-Thumb-Drive
this seems much simpler.
Old 05-23-2013, 09:22 AM
Banned
thanks for the links
what version of linux are you using ?
how is the load time vs a HD or SSD for linux from a usb3
Old 05-23-2013, 09:29 AM
nynor's Avatar
AV Linux - Install...Create...
it comes pre-configured with SEVERAL audio and video software programs for creating/editing/producing. it is also a really nice version that runs well and fast.
Old 05-23-2013, 09:33 AM
