Team California
Need adhesive that never dries:
I need some of that adhesive that is like putty but sticky(?), I've seen it in automotive apps like securing the thin plastic to a door shell under the inside panel. You can un-stick it and then re-stick it several times. I've seen it in black and grey color, but the appearance doesn't matter.
Does anyone know the product I'm talking about and where to get it? It needs to be fairly sticky. TIA as always. |
AutoBahned
dum dum aka strip caulk is one
one of gods prototypes
Butyl rubber, check with a auto body supply place
Brought to you by Carl's Jr. |
I'm with Bill
windshield urethane
Electrical problems on a pick-up will do that to a guy- 1990C4S |
How about silicon adhesive? Different from silicon caulking. Also available at hardware stores.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Almost Banned Once
- Peter |
Hey Speeder,
Try a search on vacuum bagging sealant tapes, probably fit your needs.
87 930, |
Petie3rd
go to the auto body supply store,
they sell 3M strip caulk its black and stays sticky forever, sounds like what your looking for. It comes in a blue and white box.
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Petie3rd
3M 90 spray adhesive?
Its weatherstrip adhesive....
Its made by 3m, comes in yellow or black. The NASCAR guys put the lug nuts on the rims with it... The offroad guys put it on everything, I don't know why they don't just use loctite, I think they like that if they have to take something apart it is easier. http://3mcollision.com/3m-super-weatherstrip-and-gasket-adhesive-08001-yellow.html http://3mcollision.com/3m-black-super-weatherstrip-adhesive-03602-4250.html WOOPS............ I missed the putty part..............nevermind.
1987 Carrera Last edited by Radioactive; 07-15-2013 at 07:01 PM.. |
Made me think about those mouse traps with glue...
Team California
Thanks! I'll look for the 3M stuff. It needs to stay soft forever and not dry.
MAGA
The 3M window weld is not what you are looking for as it is permanent. It sets up a bit firmer than silicone. Once cured, it will not release from properly treated/primed parts... it requires cutting off with a razor blade or saw type tool. It is the type of stuff windshield installers use to bond replacement windshields to modern cars. It is great stuff for re-bonding 924/944 rear hatch frames to the glass provided one properly treats and primes the glass and the hatch frame. It is pretty pricey and will go bad in the tube once opened.
The 3M strip caulk is something I use for bedding/sealing stuff like 944 tail lights. I am not sure if it is what you are looking for because while it does stay soft, it is not all that "sticky" if you are relying on it alone to hold something in place.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Team California
Thanks. Think about the stuff that holds the clear plastic to the sheet metal under an interior door panel, that's the type of stuff I need. I've seen in other places on vehicles, just can't recall where at the moment.
Anything that cures, (like windshield caulk), is not what I'm looking for. I have all that stuff already.
Denis |
Petie3rd
get the 3M PN 08578 this is what your looking for, see post 9
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&ved=0CFQQFjAC&url=http%3A%2F%2F3mcollision.com%2Fproducts%2Fsoun d-deadening%2F3m-strip-calk-08578-black.html&ei=p2TlUan7Oqa3ywHkmIHABA&usg=AFQjCNGuVH2L8xxXIRm28drnin8uFzwbTg&bvm=bv.48705608,d.aWc
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 07-16-2013 at 08:20 AM.. |
Team California
Awesome, thanks!
Isn't that the stuff which stinks?
Great stuff though. You might try roofing mastic tape, makes a sticky mess but never dries. EternaBond DoubleStick ![]() Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Go-Kart Mozart
Stop by your local auto glass installer and ask for a roll of butyl rope. 3M is the major player but there are others. Local place here sold me a huge roll of 5/16 for less than $20. Don't worry about the diameter too much. You can stretch it to reduce diameter. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken Last edited by JAR0023; 07-16-2013 at 11:49 AM.. |
