Banned
Who Needs Brake Paste?
Do you really need brake paste when rebuilding a caliper or doing other work?
Brake fluid seems to work ok. Does brake paste add anything? Does it make things safer? Or easier? Or what? |
Parrothead member
Are you talking about caliper slide grease?
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
D idn't E arn I t
For you, I recommend wheel bearing grease there.
rjp
AOC/Hogg 2028 |
ohhh boyyyy
Brake fluid does not mix with anything else including the paste. Brake fluid also cannot be used where the paste is used. Please do not work on your own brakes and take it to a shop.
Brake paste is probably silicone grease. Petroleum greases like wheel bearing grease can cause some types of caliper seals to swell and stick or seize and are not recommended for brakes
. Brake fluid is too fluid to stay put like a grease or paste would but does work for many assembly tasks.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
Hell Belcho
I use nasal queso
Saved by the buoyancy of citrus. |
Better check the blinker fluid while working on the brakes.
Banned
are the muffler bearing alined ?
D idn't E arn I t
AOC/Hogg 2028 |
Registered ConfUser
Mastiff spooge. I have plenty of it.
Almost Banned Once
- Peter |
AutoBahned
brake fluid is said to cause corrosion if it gets past the seals (as it is hygroscopic) - seems a bit far fetched to me as it would (should) just get washed off by rain, puddles (which also get the caliper wet)
brake fluid also will not "stay there" like brake paste I do know that some Volkswagen mechanics (the bane of 356s) will skip brake paste and just use brake fluid... I guess it is no big deal on a VW as the car will break down anyway... regular grease will drip if used b/c of the high temperatures the caliper reaches where is Dr. Brakeburg? |
I need brake paste.
No left turn un stoned |
Takin' hard left turns
Brake paste will keep the cratch from going slap slap slap, like that.
ROFL I thought that brake paste was the result of going slap, slap, slap on that cratch.
Max Sluiter
There's a Miley Cyrus joke in there somewhere.
Someone needs to stop her from slap slap slapping that cratch. Maybe brake paste will work.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Best friend is my dog
Be real caaarefull because if you apply to much brake paste to the cratch it will go flop, flop, flop.
D idn't E arn I t
will it ever run again?
Who knows!!
AOC/Hogg 2028 |
entertaining the idea
Herculiner? Just remember to wash your hands when you are done.
